August 17, 2025, 07:25:49 AM *
Author Topic: Juist ordered the Signal Dynamics voltage doohicky, now where to mount it?  (Read 780 times)
Fritz The Cat
« on: July 09, 2012, 06:41:01 PM »
Took a while but finally got around to it. It's the single LED voltage indicator. I don't see any sign of a bracket so how do you guys mount it? Tie Wrap it to the handlebars? lol
Thrud
2000 Valkyrie Interstate
« Reply #1 on: July 09, 2012, 08:29:05 PM »
I have this same accessory on my Interstate.  The LED has a small black plastic collar that you can use to mount the LED through a flat panel surface.  However, I just drilled a small hole in the panel of my faring, just small enough for the LED, and epoxyed it to the panel.  Just a couple of small drops applied with a toothpick is all you need.  Looks professional and works great.  The silver label with the instructions I applied to the chrome surface just below the gas cap.
Steve
Thrud
« Reply #2 on: July 09, 2012, 08:35:26 PM »
BTW, the sending unit can be mounted with the supplied double-sided tape to the inside of the faring.  I ran the voltage input wires to the accessory terminal, which can be found buried somewhere just in front of the battery.  It can be a b#t@h to find!
Steve
