February 05, 2026, 10:03:44 AM
Miss at wide open throttle
Topic: Miss at wide open throttle (Read 1055 times)
$ Ball
July 10, 2012, 02:33:28 PM »
Have a miss a w o t between 3000 4000 rpm
doesn't miss at 3000 and 4000 with 3/4 throttle open, idles great
K&N ,pilots at 2.25
jimmytee
Elizabethtown,KY
Re: Miss at wide open throttle
July 10, 2012, 05:59:44 PM »
When I bought my 2000 standard, it had Cobra pipes on it. It would stumble and sputter like that beween 3-4000 rpm.PO never rejetted the carbs. Changed the jets,also found a couple of broken springs,re-synced the carbs and all is well. Vacuum leaks and leaks from the intakes can also cause similar symptoms.
Last Edit: July 10, 2012, 06:14:39 PM by jimmytee
