February 05, 2026, 10:02:57 AM *
Author Topic: Final drive gear bearing removal  (Read 1142 times)
Fritz The Cat
« on: July 14, 2012, 06:41:20 AM »
Anybody know how it's done?
It's item #27 here-
http://www.cheapcycleparts.com/model_years/838-honda-1998-valkyrie-gl1500c/assemblies/12352
lee
Northeast Tennessee
« Reply #1 on: July 14, 2012, 06:54:29 AM »
Two flat screw drivers.  One on each side.  Just twist the handles its usually not that tight.
If you are replacing the ring gear and pinion that one is easy.  Number 1 bearing is the hard one.
« Last Edit: July 14, 2012, 07:01:35 AM by lee » Logged
Time is not what is taken but what remains.
C. Drewry
Fritz The Cat
« Reply #2 on: July 14, 2012, 07:11:29 AM »
Thank you sir. I didn't want to apply a whole lot of force if it required a special jig and a 20 ton press. Knowing that it did not allowed me to proceed. i had to use 2 crowbars rather than 2 screw drivers because twisting didn't budge it. But the crowbars popped it right off.  cooldude
