February 05, 2026, 10:03:55 AM
Red Rear Turnlight Lenses.
Topic: Red Rear Turnlight Lenses. (Read 1214 times)
Mr.BubblesVRCCDS0008
July 14, 2012, 10:37:58 PM »
If you want red lenses for you rear turn signals these will fit almost perfectly. If you have the two screw type remove enough of the white back of the lens to clear your bulb and drill the holes in it to mount it to the housing using the original screws (you might need shorer ones) that held the original len on then snap the red lens on and your done. If you have the single screw mount, take a 2' hole saw and remove the center of the back plate of the light then with the glue of your choosing glue the white backing in the original housing and snap the red lens on. and your done. I used JB Weld but any good glue will work as these are almost the perfect size. You can order the lights at Autozone but they charge 8.99 each for them.
http://www.amazon.com/Blazer-B827R-clearance-marker-1-each/dp/B0045LOMYA
