November 24, 2025, 10:40:50 PM
Speedometer ?
Topic: Speedometer ? (Read 1232 times)
Farther
Quimper Peninsula, WA
Speedometer ?
July 15, 2012, 02:51:39 PM »
Took the bike out for a short ride and looked down, no speed registering on the speedometer. WTF!! After a short 120 mile coffee run I disassemble the speedo cable and found the inner cable broken. New complete assembly (both inner and outer) on order but I was wondering if any one else has experienced this?
A second question: what kind of lube should be used on the inner cable?
~Farther
tank_post142
south florida
Re: Speedometer ?
July 15, 2012, 02:59:29 PM »
ive replaced mine 2-3 times over the years. use a good graphite speedo cable lube available at most auto parts stores.
I got a rock
VRCCDS0246
JaysGone
Delray Beach Florida
Re: Speedometer ?
July 15, 2012, 03:03:50 PM »
I had to replace both the cable and the front wheel hub gear when I bought my bike.
A 99 showing 12K on the odometer.
So one has to wonder what in 13+ years the mileage actually is. And why it was never fixed to begin with.
1999 Valk - SOLD
2005 Yamaha RoadStar
Re: Speedometer ?
July 15, 2012, 05:09:02 PM »
Speedo cables can break.. Mostly they break cuz they get dry and start hanging up in the cable housing.. I've always used a white lithium grease.. If the broken cable has been spinning for any amount of time it can ruin the housing.. Whenever a wheel is removed is a good time just to pull the cable and slobber on some lube..
Fritz The Cat
Re: Speedometer ?
July 15, 2012, 05:32:24 PM »
Quote from: Patrick on July 15, 2012, 05:09:02 PM
That's what I told her too.
=> InZane XXV
