November 24, 2025, 08:31:20 PM
Rear end wiring colors
Topic: Rear end wiring colors (Read 1050 times)
thedon
Wisconsin State Rep.
Watertown Wisconsin
July 16, 2012, 04:37:38 AM »
I know this has been asked 100 times, but can anyone tell me the rear wiring colors? I have installed a hitch and now need to install the Hoppy wiring harness. The harness is a 48895 which was recomended by Hoppy. I have looked under the right side cover and still don't know where to attach the wires. As you can tell, I've not done this before and don't want to make a mistake.
Thedon
Re: Rear end wiring colors
July 16, 2012, 06:12:56 AM »
thedon
Watertown Wisconsin
July 16, 2012, 06:32:57 AM »
Thanks BF, really appreciate it.
July 16, 2012, 07:38:10 AM »
Is the converter a powered one or just a 5-4 wire converter. I used Hoppe's #46255 which is powered from the battery. The unit is mounted under the seat and the trigger wires I hooked up under the rightside cover. There's a gang of disconnects for the wiring to the rear wheel.
thedon
Watertown Wisconsin
July 16, 2012, 08:37:09 AM »
It is just a 5-4 wire converter. Like I said before, I just don't want to make a mistake.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
July 16, 2012, 09:01:47 AM »
Bring it on over after work... We'll get 'er figured out
Black Dog
Don't you know...
thedon
Watertown Wisconsin
Reply #6 on:
July 16, 2012, 09:30:56 AM »
Hey, Blackdog, I don't know if I can make it tonight. It may be Tuesday night. I'll let you know.
CASABROKER
Reply #7 on:
July 16, 2012, 10:31:29 PM »
I WIRED A 4 PLUG BOUGHT A SEPARATE BRAKE LIGHT INSTALLED IN THE MIDDLE OF THE TRAILER DIRECT ONE WIRE TO BRAKE WIRE EASY AFTER I FIGURE IT OUT NO ADAPTER.
thedon
Watertown Wisconsin
Reply #8 on:
July 18, 2012, 06:19:28 PM »
Blackdog,
Awesome job. Thanks for your help with the wiring.
Thedon
=> InZane XXV
