February 05, 2026, 02:34:19 PM *
Author Topic: Strong fuel smell. . .  (Read 1945 times)
KW
West Michigan
« on: July 16, 2012, 05:39:07 AM »
Both when coming to a stop and then accelerating I get a very strong smell of gasoline. The bike is running normal with no noticeable change in MPG. It was so strong on the last outing, I stopped to check for gas leaks. Couldn't find anything, even when I got her back in the barn. Anyone have any ideas? Thanks~
Pete
« Reply #1 on: July 16, 2012, 05:50:40 AM »
Gas cap seal??
BradValk48237
Oak Park, MI
« Reply #2 on: July 16, 2012, 05:57:23 AM »
Intake o rings.... Might old and leaking.  Mine were. Also check all the intake clamps. They can be loose and cause it. I'll bet it's the intake o rings.
Brad
KW
West Michigan
« Reply #3 on: July 17, 2012, 09:48:16 AM »
I checked the clamps. . .  all of them were loose, one was about to fall off. Great tip. Haven't taken it for a test ride yet, but I'm thinking that was the problem  cooldude
(Gas cap checks out ok)
« Last Edit: July 19, 2012, 04:41:22 AM by KW » Logged
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #4 on: July 17, 2012, 10:22:28 AM »
If the intake o-rings leak is it a visible leak?  Can you usually see gas?  Thanks
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #5 on: July 17, 2012, 10:40:22 AM »
Generally when intake o-rings wear out, you can see a kind of a tobacco colored
stain around the bases of the intakes with the worn out o-rings. Mine were that way.
I'm not sure what would happen if they were so failed that liquid was leaking out, but
you'd probably know (blindfolded) that something was wrong...
KW
West Michigan
« Reply #6 on: July 18, 2012, 07:12:20 AM »
hmmm. . .  one had a little discoloration. The clamp WAS loose, but now I'm wondering if there may be something more?
BradValk48237
Oak Park, MI
« Reply #7 on: July 18, 2012, 09:17:36 AM »
Order the kit from Red Eye..... was like 6 bucks or something....And he will have them in the mail right away (had mine in 2 days regular mail)...... it is an easy fix to replace.... maybe take 30 min unless you have an I/S- taking off the pods will take longer...
All you have to do is loosen the clamp on the top of the intake tube and the 2 screws ay the bottom... kinda push em up a bit and pull forward- them pop right out...... replace the o ring and reverse the order yo replace.....
Mine were all leaking, but only showed the dark spot on one of them , but there was gas all under and outside the O ring......
The o rings were visibly flattened and distorted...... EASY FIX!
Brad
indybobm
Franklin, Indiana VRCC # 5258
« Reply #8 on: July 18, 2012, 10:39:43 AM »
Gas smell happened to me once. Pushed on the gas cap and heard it click. Gas smell went away. Evidently, I did not close it all the when I got gas.
So many roads, so little time
VRCC # 5258
KW
West Michigan
« Reply #9 on: July 18, 2012, 08:07:14 PM »
Brad; was there any noticable change in performance and/or mpg? Just wondering. Everything appears ok, but I'll check everything out when I return from out west.
BradValk48237
Oak Park, MI
« Reply #10 on: July 19, 2012, 06:50:56 AM »
I would say less popping, but I need some carb work.......
MPG?!??!?  Don't know... I just fill it up when it gets low...... Wink
Definitely got rid of the gas smell!
B
KW
West Michigan
« Reply #11 on: July 30, 2012, 05:10:03 AM »
FYI - It was the clamps. . . . . thanks for the help  cooldude
