February 06, 2026, 06:42:45 PM *
Author Topic: Something here ain't right  (Read 3416 times)
YoungPUP
Valparaiso, In
« on: July 16, 2012, 06:23:13 PM »
Have noticed that of recent rides that the normal bike in neutral clutch out noise is getting louder.  Now this morning I noticed what sounded like a bearing clattering while the clutch was out. IT goes away when the clutch is pulled in.  Where to start?  IS this other post a possibility?http://www.valkyrieforum.com/bbs/index.php/topic,42568.0.html. If so is this a job for a good home mechanic?  I'm by no means a pro, but know how/can rebuild car engines etc.
99 STD (Under construction)
Michvalk
Remus, Mi
« Reply #1 on: July 16, 2012, 11:23:28 PM »
I don't know all the proper names for the parts, but, there is a pin between the clutch actuator and the clutch. It comes out when you remove the hydrolic actuator. Needs grease.... That's where I would start, see if that pin needs lubed. cooldude
junior
new hampshire
« Reply #2 on: July 17, 2012, 01:57:00 AM »
 thats where mine was making noise
« Reply #3 on: July 17, 2012, 07:15:27 PM »
On back of the engine from underneith is 3 bolts. I think the clutch line goes into it. Remove kickstand bracket and them 3 bolts. Pull it out and grease the pin. Fairly easy to do.
Allan
My 97 std.
Kastrup, Denmark, Europe
« Reply #4 on: July 18, 2012, 01:52:53 AM »
Mine had almost no sound with the clutch out. A grinding sound came, when I pulled the clutch from just half an inch and all the way in. After a few seconds in, the sound stopped almost totally.
I´m with Mickvalk on this!
Good luck!
Rosie
Clintonville WI 54929
« Reply #5 on: July 22, 2012, 05:39:43 PM »
Let me know what you do to rectify this noise and how big a job it is. Mine just started where I can feel a little roughness on clutch lever : clutch out toching lever   Pull lever in and smoooth as silk only notice in neutral. Plan on doing over winter unless it gets worse. Thanks
1999 Valkyrie tourer
2003 Valkyrie standard
YoungPUP
Valparaiso, In
« Reply #6 on: July 22, 2012, 06:01:40 PM »
Not very hard at all. Put Valk up on jackstands, pulled the kickstand assembly ( I'm lazy, used air tools) Pullled the 3 bolts for the slave cylinder, greased the little pushrod thingy and reversed disassembly.  So far so good....
junior
new hampshire
« Reply #7 on: July 23, 2012, 01:43:49 AM »
i didnt remove the kickstand.......................
NITRO
Eau Claire, WI
« Reply #8 on: April 30, 2013, 10:47:44 AM »
Glad I found this, just noticed the same thing with mine this spring. I was worried it was an issue with the clutch rivets or some other horrible problem. Looking forward to getting this fixed this weekend.
When in doubt, ride.
hoosier jaybird
NE IN.
« Reply #9 on: April 30, 2013, 05:20:24 PM »
Thanks young pup for bringing this up. I thought that the roughness I felt and heard in neutral with the clutch out did'nt seem right. If simply lubing the push rod quites it down , wonderful. And Junior, apparently there is enough clearence to get that 1 bolt out without removing the kickstand bracket?
YoungPUP
Valparaiso, In
« Reply #10 on: April 30, 2013, 05:44:05 PM »
Glad this helped ya!  cooldude Almost a year later and still all good.  I've talked with a few people afterwards and it seems that pulling the kickstand is a case by case basis.  Good luck.
hoosier jaybird
NE IN.
« Reply #11 on: April 30, 2013, 06:21:31 PM »
Young Pup, since this is a wet clutch do you need to drain the oil before pulling the clutch slave cylinder to lube the push rod? Apparently the push rod does not come in contact with the lube oil?
