November 24, 2025, 08:41:31 PM *
Author Topic: Can this be done...front fender removal without removing the wheel?  (Read 1867 times)
wiggydotcom
Yorkville, Illinois
« on: July 18, 2012, 07:45:25 PM »
I'm wanting to install a chrome front fender extension and was wanting to know if the fender will lift up and clear the forks without taking the wheel off first? If I have to bite the bullet and put it on the jack, it won't be the first time but was looking for a short cut. Doing a tech search didn't get me anywhere. Any help would be appreciated. Thanks..
VRCC #10177
VRCCDS #239
tank_post142
south florida
« Reply #1 on: July 18, 2012, 07:48:22 PM »
drop the calipers, unbolt the fender and slide it out.
I got a rock Sad
VRCCDS0246
wiggydotcom
Yorkville, Illinois
« Reply #2 on: July 18, 2012, 08:10:18 PM »
Thanks, Tank....gonna go try it now. Wasn't sure about clearance issues.  cooldude
VRCC #10177
VRCCDS #239
R J MILES
« Reply #3 on: July 18, 2012, 11:17:23 PM »
Let the air out of the tire. Put block of wood to keep from drilling into tire.   Fuzzy
« Reply #4 on: July 19, 2012, 06:13:20 AM »
You don't have to take off your calipers.  You don't have to take anything off except to unbolt the fender and the speedo cable from the fender.
That said, it WILL NOT just slide right out....it's close, but not quite....however, it will come out simply by holding boths sides of the fender and squeezing the fender enough to clear the forks.
After you install your fender extension, squeeze it together again to go back in between the fork tubes.
You can also help to protect the fender by slathering a bunch of blue painters tape all over the sides of it prior to removing it past the fork tubes.
The above method worked great for me.
tank_post142
south florida
« Reply #5 on: July 19, 2012, 06:16:26 AM »
sorry , i would have sworn i had to remove the calipers, i was wrong. Undecided
I got a rock Sad
VRCCDS0246
« Reply #6 on: July 19, 2012, 06:28:09 AM »
I didn't see any reason to take 'em off myself.
DLSSOJC
« Reply #7 on: July 19, 2012, 06:37:26 AM »
No problem here either, just have to squeeze in the fender just a little to clear the forks.  cooldude
wiggydotcom
Yorkville, Illinois
« Reply #8 on: July 19, 2012, 04:30:56 PM »
Thanks all, I've been in that spot before where I was hesitant to persuade it by squeezing it after lifting.
It worked like a charm. Chrome extension is on..  Smiley
VRCC #10177
VRCCDS #239
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #9 on: July 19, 2012, 05:33:23 PM »
Yep same on a Rune...but on the Rune you have to remove the fender to get the wheel off...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
