February 07, 2026, 07:47:37 AM *
Author Topic: general questions  (Read 2056 times)
amungus
« on: July 20, 2012, 03:23:55 PM »
I have a 2001 Valk IS. The faring is so close to the handle bars it hit when going over bumps. Is there a way to adjust the faring?
Second issue- I have developed a squeek between 30 and 40 Mph(@ least thats when I hear it). Seems to be on shaft side. Any ideas??? wheel bearing???,.
MP
North Dakota
« Reply #1 on: July 20, 2012, 04:34:58 PM »
How about moving the handlebars down some?  Rotate them down a little??
MP
"Ridin' with Cycho"
Big Tom 10628
Surprise AZ.
« Reply #2 on: July 20, 2012, 04:51:53 PM »
MP
If you rotate the handlebars be sure to put a cushion on the tank, like a folded towel.  You will, dent the tank when the bars drop after the last bolt comes loose..
1999 Valkyrie Interstate
2006 Gold Wing
« Reply #3 on: July 20, 2012, 05:04:54 PM »
Have you looked for the squeak ?? It could be a shock bushing as well as many other things..
tank_post142
south florida
« Reply #4 on: July 21, 2012, 01:13:06 AM »
" Have you looked for the squeak ?? It could be a shock bushing as well as many other things.."
loose exhaust, loose saddlebag, giant RAT in the right saddlebag?
I got a rock Sad
VRCCDS0246
justintyper
syracuse,ny
« Reply #5 on: July 21, 2012, 08:38:04 AM »
i had the squeak noise you speak of and turned out to have dry splines between the whell and final drive... id check that out just to make sure...
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #6 on: July 22, 2012, 06:12:07 AM »
The squeak as you describe it sounds like rear wheel bearings to me...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
« Reply #7 on: July 22, 2012, 11:32:09 AM »
When you hear the noise, take your fully prepared water pistol and spray the rear brake caliper and rotor.
The noise should disappear if it is rear brake related, which is what I think it is.
Do more "Oh that!" investigation.  Precious little information up till now.
« Reply #8 on: July 22, 2012, 05:33:27 PM »
When my left rear wheel bearing went out, it sounded like something was chewing rocks whenever I applied the rear brakes.
It sure as heck didn't squeak.
« Reply #9 on: July 22, 2012, 05:38:29 PM »
Chewing rocks was exactly the noise I got from mine too (with steel teeth).   cooldude
sugerbear
wentzville mo
« Reply #10 on: July 22, 2012, 06:08:30 PM »
as for the fairing. take off the speaker panels. (watch the brass inserts). check the mounting brackets (4). anything bent/loose?
do you have aftermarket risers. could they have been put on backwards? should lean toward the rear.
 Smiley
steve 3054
VRCC # 34853
« Reply #11 on: July 23, 2012, 08:57:43 AM »
???  Mine squealled like a girl ... cooldude
 meet.
amungus
« Reply #12 on: July 28, 2013, 08:46:42 AM »
It's not the handle bars it's the handle bar riser it self.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #13 on: July 28, 2013, 09:17:05 AM »
If you're able to post a picture here of the problem area, it'll make life much easier for the gurus of the board (I'm not one of them) to diagnose it.   Wink
