February 05, 2026, 01:08:14 PM *
Author Topic: Dyna Beads and Green Slime....  (Read 5433 times)
Big Rig
Woolwich NJ
« on: July 21, 2012, 06:11:12 PM »
OK, a question was raised at dinner with a couple guys I ride with, we all use Dyan Beads and one of my guys had a puncture last week and used a can of slime...he has/had dyan beads in, will that affect the balance of his wheel?
I am not too familiar with Green Slime (Green fix-a-flat), he said it remains in liquig form?? Is this true?
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: July 21, 2012, 06:22:35 PM »
Doesn't matter.  Dyna beads says tire sealant will make the beads clump.  Clumping beads means the tire will not be balanced.  In addition, slime is not compatible with aluminum wheels.
Marty
tank_post142
south florida
« Reply #2 on: July 21, 2012, 06:54:00 PM »
hell yah! itg will eat that rim alive! and pretty quick
I got a rock Sad
VRCCDS0246
Big Rig
Woolwich NJ
« Reply #3 on: July 21, 2012, 06:57:57 PM »
I will let him know....
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #4 on: July 21, 2012, 07:12:23 PM »
Why not use RIDE-ON and get sealing and balancing out of one bottle?  I've used it for years, wouldn't ride without it.
Save a horse, ride a Valkyrie
« Reply #5 on: July 22, 2012, 01:02:02 AM »
Not only that, Slime is only a temporary fix, like till you can get it to a repair shop today. Leave it in to long, and it will start to leak again.
It did it's job, it got you back on the road, now it has to be fully cleaned and the tire repaired.
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #6 on: July 22, 2012, 05:19:27 AM »
Exactly!   cooldude
X Ring
« Reply #7 on: July 22, 2012, 08:01:45 AM »
Exactly!   cooldude
I use it also!
Marty
YoungPUP
Valparaiso, In
« Reply #8 on: July 22, 2012, 08:56:18 AM »
Make sure he lets the tire shop know before they tear into the tire. Most have a healthy cleanup fee if you suprise them with that stuff.
99 STD (Under construction)
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #9 on: July 22, 2012, 09:53:07 AM »
Exactly!   cooldude
I use it also!
Ditto again  cooldude
Marty
Big Rig
Woolwich NJ
« Reply #10 on: July 22, 2012, 06:03:15 PM »
Your not kidding about the mess, we tour into it today...and I will tell you that stuff does not smell too goof...Clean, plug, patch and new dyna beads...no sign of damage to his rim that we could find....he has some serious $$$$ in  those rims.
He said his wife said his face went ashen when I told him that crap will eat his rims...
Free dinner and a couple beers, I like working on his harley...
« Reply #11 on: July 22, 2012, 06:28:33 PM »
from slime site
•I’ve heard that Slime will ruin my rims?
Our Slime Sealant for tubeless tires is formulated with rust and corrosion inhibitors as well as a pH buffer making the product more alkaline. All of these ingredients work to protect the integrity of your rim. It is important to note there are factors which can allow damage to occur in spite of this. If you want to err on the side of caution, you can use Slime as a roadside repair. All you need is Slime and an air compressor! Slime can have an adverse affect on certain types of aluminum rims. Because alloys differ, it is difficult to predict how Slime will react with your rims specifically. Over the years, though, we have found that older rims are more susceptible to damage from Slime. Make sure that, if you have tubeless tires, you are using our tubeless formula. Our inner tube formula does not contain rust and corrosion inhibitors. Do not leave Slime inside your tires for more than 2 years. After that time, we cannot guarantee the integrity of your rims. If pre-existing damage is present, we do not recommend using Slime.
http://www.slime.com/category/faqs/
John U.
Southern Delaware
« Reply #12 on: July 22, 2012, 07:20:14 PM »
from slime site
Though Ride-on claims not to damage aluminum rims, I suggest (based on bad experience) that under certain conditions Ride-on can also damage rims. If you want to err on the side of caution, coat the interior surfaces of your rims or don't leave Ride-on, Slime  or any of the other flat sealants in your tires for long periods.
This has been discussed here before and recently with a representative of Ride-on, who can't explain why my rim was corroded with their product in the tire. I got no offers to replace the rim, just a friendly conversation which accomplished nothing. So the bottom line is, if your rims are damaged, you are out the rim. Ride-on will sound very concerned and incredulous but they offer nothing other than vague mention of possible interactions with tire mount lube.
Did you completely remove the tire mount lube? Is that even possible? But the tire mount lube also claims to be non-corrosive....tsk, tsk.
I will coat the inner surfaces before I use any of it again, replacing rims every time i replace tires is too much to pay for avoiding flats.
MP
North Dakota
« Reply #13 on: July 23, 2012, 04:33:52 AM »
from slime site
I do NOT read it that way.  Here is the quote from above:
" Slime can have an adverse affect on certain types of aluminum rims."
I read it as " we may well damage your aluminum rims.  Use at your own risk"
MP
"Ridin' with Cycho"
JC
The Beast
Franklin, TN
« Reply #14 on: July 23, 2012, 09:13:12 AM »
Exactly!   cooldude
+3   cooldude  Ride-on rocks!
