February 05, 2026, 11:50:03 AM *
Author Topic: pods  (Read 1241 times)
spurliner
alberta.....near calgary
« on: July 21, 2012, 10:05:18 PM »
Did a search-can't find what i need to know. How does one remove the radiator pods? I'm baffled.
1999 Interstate--
Mr.BubblesVRCCDS0008
« Reply #1 on: July 21, 2012, 10:28:16 PM »
Three allen head screws, one at top, one at the bottom and one up front by radiator. There is also a tap in the rear section that just pulls out to the side. Be sure not to put the bottom screw (longer one) back in the wrong spot or you could punture you radiator.
spurliner
« Reply #2 on: July 22, 2012, 06:52:15 AM »
thanks. I have lights in my pods- is it the same procedure?
1999 Interstate--
sugerbear
wentzville mo
« Reply #3 on: July 22, 2012, 07:34:53 AM »
should be. unless it's been removed, there is a rubber air deflector inside(it's a part of the pod) . it kinda tough to get around when taking off and putting back on. take your time. Smiley
