February 05, 2026, 11:50:05 AM
Pinion Cup Maint, What do I do?
Topic: Pinion Cup Maint, What do I do? (Read 1358 times)
ValkSmile
Cincinnati, OH
July 23, 2012, 10:53:59 AM »
Does anyone have a link or pics to pinion cup maint? I did a search for Pinion Cup and there is so much stuff listed I just thought I would ask. I have to replace u-joint so I just wanted to know how to check the pinion cup while I have the whole thing apart. Thanks
Re: Pinion Cup Maint, What do I do?
July 23, 2012, 10:55:43 AM »
Pull the drive shaft out (from the pumpkin) when you do the work.
Easy enough to see what you need.
July 23, 2012, 11:18:29 AM »
When you remove the rear drive, just wiggle the shaft and pull to get it out.. You'll easily see everything.. If the cup needs replacing, its just held in the one pinion retainer nut..
July 23, 2012, 12:10:54 PM »
After removing the shaft from the pinion cup, clean the parts of all the old grease. Look down into the cup and see 2 holes that should be open and not clogged with grease. Relube with a moly grease and reassemble.
