February 05, 2026, 01:16:08 PM *
Author Topic: starter solinoid  (Read 1392 times)
Maldog
Woodstock IL
« on: July 23, 2012, 02:26:16 PM »
Hay Guys I have to put a new starter solinoid on my IS the orignal  plug with the wres melted so Ijust have 3 male ends on the  individual wires,my question is can one of you tell me which male lead on my new solinoid doe the three wires go to,also is the clymer service manual a good  buy does it have all the same info as th Honda factory manual
« Reply #1 on: July 23, 2012, 04:35:47 PM »
You will need a new relay part number 35850-MT4-000
Send a private message to R J, he can help you with the wiring.  Hoser
http://www.valkyrieforum.com/bbs/index.php?action=profile;u=79
« Last Edit: July 23, 2012, 04:46:59 PM by Hoser » Logged
Rattlebars
Liberty Ohio
« Reply #2 on: July 23, 2012, 07:17:20 PM »
PM is not the way to go since the next guy might find his answer here.
The wire colors are shown as the plug sits. The red wire feeds the ignition switch and needs the 30 amp fuse. Best bet is eliminate that wire from the top of the start relay since that's the wire that corrodes and heats up.  Go to Radio Shack and get a 270-1234 in line fuse holder. It's waterproof. Get a pack of 64-3040 ring terminals and use the middle sized one on one end of the fuze holder.  Cut the plastic off and SOLDER it or it will just start doing the same thing in a different place. Cut the spade on the bike's RED wire off and solder that RED WIRE to the other end of the fuse holder. Take the top screw out of your DOGBONE and put the ring terminal there then screw it back in. That will get the heater away from the expensive relay.
Pop the green cap off the relay to expose the terminals. Clean the heck out of them with sandpaper and baking soda. Take the plug with the YELLOW/RED wire attached and if it's still good, plug it onto the left terminal closest to where the fuse was (see pic).  The other wire that has two wires going to it GREEN/RED goes on the other terminal closest to where the fuse was. If either of these spades are corroded, replace them and SOLDER.
Put heat shrink on the spades all the way down (remember, your green protector is probably gone, but if not, put it back on) and put an extra empty spade on the terminal that once had the offending RED wire on it.  That RED one was the wire that caused your plug to melt because it was always hot while the bike was turned on. The YELLOW/RED is only hot when you press the start button so it won't start grabbing oxygen from the air and corroding and heating up.  Insulate the rest of the terminals and if you have some silicon calking, cover them. If you have some, spray some battery terminal gunk on the relay terminals.
I would have more and will have more in a coupla days. I'm going to head over to a friends to fix his melted plug and will document with pics. This will cost you some time and about $6 bucks instead of $80 for a new relay and even if you get that, you still have to deal with that fugly melted top plug.
(this post may be edited as I work through the process).
>FUSE HOLDER<
>TERMIALS<
>MORE INFO<
« Last Edit: July 23, 2012, 07:23:47 PM by Rattlebars » Logged
Have you had your pre-frontal Limbaughtomy today?
'98 Valkyrie NYTMR
Vietnam Vet - Infantry Recon '66-'71
Rattlebars
Liberty Ohio
« Reply #3 on: July 25, 2012, 03:10:28 AM »
Write up is complete. Your start relay/solenoid is probably ok, just needs a little work and about $6 worth of parts.
Complete write up here >CLICK<
Or just click the pic below:
'98 Valkyrie NYTMR
Maldog
Woodstock IL
« Reply #4 on: July 26, 2012, 05:25:14 PM »
wow Rattlebars ,thanks a bunch also sent u a privatr message  i went and looked at my bike and i discovered  my wires are 1 red. 1 green red and 2 yellow red  can u tell me why the discrepancy ,hmmmm also My Valk is a 2001 Interstate if this helps I donnno lol
