February 05, 2026, 11:50:04 AM *
Author Topic: slight rust inside swingarm  (Read 1312 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: July 24, 2012, 05:17:04 PM »
I have slight rust inside the swingarm and some on the outside of the pinion cup.  It is  99 with 50k on it.
What should I be concerned about? How should I clean it? should I put a little gasket sealer on the pumpkin when reattaching to the swingarm? Anything else?
Also if you hold the pumpkin with the pinion cup pointed down should gear lube run out the pinion cup?
« Last Edit: July 24, 2012, 06:02:17 PM by Zeus661 » Logged
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Michvalk
Remus, Mi
« Reply #1 on: July 24, 2012, 06:17:43 PM »
I don't think that the punkin needs a gasket or sealer. There is a seal where the driveshaft goes into the cup. Is the Boot over the universal not on correctly? That is the spot water can come in easiest. I think the swingarm has a drain hole in the bottom, can't remember for sure. But the answer to your question is ,no, no sealer required cooldude
Your punkin has holes in the pinion cup area to allow lube to vent into the cup. So yes, lube will drain out of those holes into the cup area. Make sure those holes are clear, aand put a slight bit of moly grease on the gear surfaces befor reinstaling. Have you pulled the driveshaft out of the cup yet? The seal should pop out with the driveshaft. Make sure that seal is reinstalled correctly. There are quite a few threads about rear maintance on the tech board. Remember search is your friend. There will be pictures and explanations on how to do the whole procedure cooldude
« Last Edit: July 24, 2012, 06:24:11 PM by Michvalk » Logged
YoungPUP
Valparaiso, In
« Reply #2 on: July 24, 2012, 06:23:53 PM »
The answer to your gearlube question is yes.
99 STD (Under construction)
« Reply #3 on: July 24, 2012, 08:42:31 PM »
Spray some Corrosion Block into the swingarm housing. Boaters use it on tools and other metal parts. Try WestMarine.com for a source.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #4 on: July 25, 2012, 04:01:41 AM »
Thanks for the replies. All is well.
9Ball
« Reply #5 on: July 25, 2012, 05:43:59 AM »
regarding rust in hidden places, DON'T look inside your headlight bucket..... Shocked
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #6 on: July 25, 2012, 01:27:00 PM »
Found and fixed about 5 years ago.
