February 05, 2026, 01:23:40 PM *
Author Topic: What the heck was it?  (Read 1694 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: July 27, 2012, 04:30:16 AM »
I have been looking but can't find it.
I read here several days ago about greasing something underneath the bike by removing 2 or 3 bolts near the kick stand, sliding it out, greasing it, and re-installing it.  Some kind of push rob I think?
Can someone help me out?  And what are the symptoms of it needing greased?  Sjoptalk link?
Thanks a bunch.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Bone
« Reply #1 on: July 27, 2012, 04:46:11 AM »
push rod for the clutch ?
Bone
« Reply #2 on: July 27, 2012, 04:54:42 AM »
Is this the one ?
http://www.valkyrieforum.com/bbs/index.php/topic,44997.0.html
« Reply #3 on: July 27, 2012, 06:36:30 AM »
Thanks a bunch.
Not something that normally requires maintenance.
RP#62
Gilbert, AZ
« Reply #4 on: July 28, 2012, 06:45:14 PM »
If you hear a chirping noise while you're riding and it goes away as soon as you put the slightest pressure on the clutch lever, then you need to grease the clutch pushrod.  That's what you were probably reading about.  To get to it, you have to remove the clutch slave cylinder on the back of the clutch housing.  Its not really a preventative maintenance item.  You do it if you need to, otherwise don't worry about it.
-RP
