January 28, 2026, 08:04:53 PM *
Author Topic: lift adapter  (Read 2274 times)
tjb
« on: June 04, 2009, 05:36:52 AM »
A couple years ago I got the dimentions to a lift adapter made out of 2x4, 2x4 and plywood.  Does anyone know how to find that post with its picture.  I have tried everything but can't find it!
Help,
tjb
John G.
SC
« Reply #1 on: June 04, 2009, 05:55:38 AM »
This what you looking for?  Check it out cause it seems to be backwards?????
tjb
« Reply #2 on: June 04, 2009, 06:20:45 AM »
Thanks John for the reply.  That is the adapter that I was looking for.
Ride Safe,
tjb
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #3 on: June 04, 2009, 06:44:55 AM »
Mine is very similar except for the left side post.  It is actually 5 5/8" because it fits into the indentation of the kickstand bracket.  Also, I notched out a hole for the oil drain plug, but did not worry about the drain hoses.  The left side fits up against the kickststand spring...I may make a notch for it - now that I've seen the "Iron Butt" version!
