August 13, 2025, 07:23:42 PM *
Author Topic: Dead miss at high RPM's  (Read 2709 times)
Bad-dragon
« on: July 31, 2012, 06:59:06 PM »
Hi, My names Talan, and I have a Valkyrie problem.  Embarrassed
Purchased my 97 valk with 72k miles 2 months ago, had a couple minor problems which I have been able to fix (mostly as a result of a dyna 3000) but 1 left I can't nail down.  At WOT or slow roll on, I have a dead miss at high RPM's (~5500+).  This limits me to about 90 mph and takes alot of fun out of racing harley's light to light. I feel like its electrical based on how it stumbles.  I thought it may have been a coil, but after replacing all three, I was wrong.  Any thoughts?
A couple things about the "Bad-dragon": pingel petcock & in-line filter, 6degree trigger wheel, 90# springs, thunder headers, de-smog, airbox mod (no foam dividers and back half removed).
First post, help would be greatly appreciated!
Michvalk
Remus, Mi
« Reply #1 on: July 31, 2012, 07:04:10 PM »
I have never heard of anyone getting a Valk to run right after doing an airbox mod. cooldude
« Reply #2 on: July 31, 2012, 07:17:10 PM »
are you sure about the rpm....there is a rev limiter at somewhere around 7K and going through the gears racing its not thta hard to hit it
Bad-dragon
« Reply #3 on: July 31, 2012, 07:20:44 PM »
Dad has a valk and said the same thing.  Cool
However, this is not a lack of power or a consistent issue at high RPM's but more of a violent jerk every .5 seconds (albeit random), which is why I was leaning to electrical...
Not rev limiter either it is a problem from 5000 (or so) through red line.
I should add it will run smoothly to rev limiter without issue when in neutral.
« Reply #4 on: July 31, 2012, 07:49:50 PM »
What condition are the plug wires? Higher revs will create more vibration, I wonder if you have a loose /broken ignition wire? Have you serviced the kill switch? Just ideas. I think your suspicion of this being an electrical issue is good thinking.  Undecided
My rides:
John U.
Southern Delaware
« Reply #5 on: July 31, 2012, 09:21:48 PM »
It could also be  spark plug. They are more likely to miss under load so the fact that it doesn't miss when in neutral might indicate a bad plug.
RP#62
Gilbert, AZ
« Reply #6 on: August 01, 2012, 05:12:42 AM »
I've heard of some fuel filters limiting flow at high rpm.  I'd pull it out and see if it makes a difference.
-RP
custom1
01 Interstate
SW Pa
« Reply #7 on: August 01, 2012, 10:36:15 AM »
A violent jerk every .5 seconds only under load?     Sounds more like the pinion cup teeth may be about gone.? Have you looked in there lately?
John
Bad-dragon
« Reply #8 on: August 01, 2012, 06:16:35 PM »
Have the rear wheel and drive assembly apart now for unrelated reasons, I will check the pinion cup while I have it off.
Spark plugs are new but the wires appear original. OEM good enough or is there an aftermarket recommendation? I'd like to take the "Tim the Toolman" approach if its available...
Thanks for the input!
Blackduck
West Australia
« Reply #9 on: August 02, 2012, 01:13:51 AM »
   If you have opened up the air box then you are lucky to even get to 5000 rpm.
Just removing the foam pad requires a couple of size larger main jets (been there and seen what happens, a big flat spot on acceleration). Any additional enlargement of the intake tract will require even larger jets. If you have opend the airbox up try using some duct tape to blank of the extra opening and see how it performs.
The mods to this airbox required 130 mains to get it running right.
Cheers Steve
« Last Edit: August 02, 2012, 01:22:27 AM by Blackduck » Logged
JaysGone
Delray Beach Florida
« Reply #10 on: August 02, 2012, 04:47:18 AM »
I too tried opening up the air box.
Not a good thing.
PinWall on Ebay has tons of used ones for $10 plus shipping.
Id replace it and leave it stock.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
crazydago
« Reply #11 on: August 02, 2012, 06:23:12 AM »
 crazy2 Is it possible that you have too much advance with a trigger wheel and a DYNA 3000? Put your stock ECM back and try it to see if it  makes a diff.  BERT
« Reply #12 on: August 02, 2012, 11:59:34 AM »
I concur with the idea of getting that air box back to stock. Make sure what you have for carb jets and adjust accordingly to compliment that stock box. I would use OEM plug wires. FWIW.   Roll Eyes
« Last Edit: September 23, 2012, 07:07:21 PM by salty1 » Logged
My rides:
Bad-dragon
« Reply #13 on: August 02, 2012, 03:53:15 PM »
Cheers Steve
Dyna 3000 failed (same ol same ol from what I've read tickedoff ) so I have the stock ECM on there,  I was told the jets were 103's, but not verified.  for some reason I didn't think about getting the airbox on ebay. I'll get it on order.
God bless Pinwall....
« Reply #14 on: August 02, 2012, 04:35:33 PM »
I'm not aware of anyone that really had the airbox modifications work as they expected.. Huge jets were required,, a whole bigger than 103s,, and the engines still would run terrible..
Honda got it right,, and all the standard issue stuff works well.. The IS ECM, 100 mains and a regular airbox should fix your problem..
MP
North Dakota
« Reply #15 on: August 02, 2012, 05:00:40 PM »
Step one:  And sounds like you are doing it, is get another airbox from pinwall.  Do NOT do ANYTHING else until you get that back to OEM.  EVERY airbox mod I have heard of really messes things up.
MP
"Ridin' with Cycho"
Blackduck
West Australia
« Reply #16 on: August 02, 2012, 06:30:15 PM »
Messing with the airbox does cause problems and takes some sorting.
Have mine running right and the pic above is the current configuration.
Gets reasonable mileage and runs fine.
Each to thgeir own.
Cheers Steve
Bad-dragon
« Reply #17 on: September 23, 2012, 04:28:03 PM »
Fixed! Thank you for all your input!
It was 98% airbox! I just can't believe it! runs like a bat out of hell.
Thanks for your help!
« Reply #18 on: September 23, 2012, 07:09:32 PM »
Glad your dragon is hauling ash again! Grin
« Last Edit: September 24, 2012, 06:49:16 PM by salty1 » Logged
My rides:
Blackduck
West Australia
« Reply #19 on: September 24, 2012, 02:44:15 PM »
As a matter of interest what did you do to sort this problem?
Cheers Steve
« Reply #20 on: September 24, 2012, 03:00:31 PM »
Well, 98% was the airbox.  I don't know what the other 2% was.
Hay  Cool
Bad-dragon
« Reply #21 on: September 24, 2012, 03:30:43 PM »
Hay  Cool
Well...the other 2% was the somewhat embarrassing part I was going to leave out. My U-joint was coming apart, which was providing extra symptoms. I guess I couldn't hear it "clunk" over the pipes.
anyway it blew apart at 60 mph, which was exciting.
« Reply #22 on: September 24, 2012, 07:07:19 PM »
Hmmmm.  Not embarrassing at all.  It has happened to others somewhat close to me.  Smiley
Hope it didn't take out anything else on its way out.
Hay Cool
