April 02, 2026, 05:05:29 PM *
Author Topic: Need starter solenoid with red connector and 2-3 inches of wire  (Read 656 times)
bluegrassguy
STANWOOD, wA.
« on: August 01, 2012, 05:08:18 AM »
found one thanks
« Last Edit: March 29, 2014, 08:13:27 PM by bluegrassguy » Logged
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: August 01, 2012, 05:18:56 AM »
Here's a link for this topic from tech board.  There is a goldwing part that can be easily modded to work.  For the valkyrie there is no repair except the entire wiring harness.
Ride Safe
« Reply #2 on: August 01, 2012, 10:15:01 AM »
If I remember correctly it was RJ that came up with that fix.. He shows it everytime there is a problem,, so,, he'll probably answer as soon as  he sees it.. I'd like to see the part numbers too..
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #3 on: August 01, 2012, 10:50:44 AM »
Are you looking for a relay like this?
http://www.ebay.com/itm/Starter-Solenoid-Relay-Honda-M-C-1500-GL1500-VALKYRIE-/270626927952?hash=item3f029f3550&item=270626927952&pt=Motorcycles_Parts_Accessories&vxp=mtr
Save a horse, ride a Valkyrie
« Reply #4 on: August 01, 2012, 01:12:36 PM »
Tech questions should really be on the tech board.. I'll go ask RJ there..
« Reply #5 on: August 01, 2012, 01:23:34 PM »
Here is a link to what you want.
Lots of good information on this document, so stick it in your favorites.
http://www.jkozloski.com/generic_parts.htm
It is in the lower right column.
