November 24, 2025, 10:22:34 PM *
Author Topic: Why do the (tire) dots go where they do?  (Read 1432 times)
Thrud
2000 Valkyrie Interstate
« on: August 02, 2012, 07:11:12 AM »
Fellow Valk riders,
I just received my Yokohama AVID ENVigor 205/60/16 V-rated tire from Discount Tire Direct.  $103 with shipping.  The tire has an awesome directional tread pattern and rounded edges.  This will be my first car tire and I can't wait to try it out on my 2000 Interstate.
The tire came with Red and Yellow dots on the sidewall.  I knew these dots had to do something with the high/low spots on the tire but I didn't know the difference, so I did a little research and come up with the following link that explains it all:
Why do the dots go where they do
http://www.bridgestonetrucktires.com/publications/ra_v13_i1/PDF/ra_v13i1%20ask%20doc.pdf
Correct me if I'm wrong, but I'll be mounting the Red dot next to the valve stem.
I'll provide a report on the tire's fit and performance to the board.
Steve (Flat6)
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #1 on: August 02, 2012, 07:31:49 AM »
Red dot next to valve stem - you got it.
Don't be surprised if there is still some weight needed to balance the tire, especially with your combo, unless you're running dyna beads or ride-on.
cutter
Plantersville, Texas
« Reply #2 on: August 02, 2012, 07:49:02 AM »
That is my tire of choice too  cooldude Will be ordering up my 3rd one this weekend. Been getting them through TireRack.com. I use 3oz's of Dyna beads @ 35psi.
DarkSideR
Pueblo, Colorado
« Reply #3 on: August 03, 2012, 02:05:35 PM »
I have a Goodyear Triple Tread on the rear (205-60). The balancing weights fell off after a couple thousand miles. I now have 13k miles on the tire with no issues. At speed everything is fine. Tire isn't showing any odd signs of wear.
Just food for thought if you don't have means of balancing the tire.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
wiggydotcom
Yorkville, Illinois
« Reply #4 on: August 05, 2012, 09:08:40 PM »
Hmmm, maybe I'm the only one on earth but my rim's heavy spot was not at the valve stem. It's easy to check with a static balancer. I wouldn't necessarily assume the valve stem is the heavy spot.
« Last Edit: August 07, 2012, 04:49:33 AM by wiggydotcom » Logged
VRCC #10177
VRCCDS #239
Daniel Meyer
The State of confusion.
« Reply #5 on: August 06, 2012, 06:33:58 AM »
Hmmm, maybe I'm the only one on earth but my rim's heavy spot was not at the valve stem. It's easy to check with a static balancer. I wouldn't necessary assume the valve stem is the heavy spot.
Pretty common on Honda rims for the heavy spot to be elsewhere on the rim. They usually put a dot on the rim (black) at the heavy spot. If you have the polished/clearcoated rims it might even still be there! Smiley
CUAgain,
Daniel Meyer
wiggydotcom
Yorkville, Illinois
« Reply #6 on: August 06, 2012, 11:59:14 AM »
Oh wow, I've been trying to scrub that black spot off for years! j/k
VRCC #10177
VRCCDS #239
