February 05, 2026, 02:38:06 PM
Where's the best place to mount this?
Topic: Where's the best place to mount this? (Read 2037 times)
Fritz The Cat
August 02, 2012, 01:17:26 PM »
http://signaldynamics.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=56&category_id=14&option=com_virtuemart&Itemid=77
The indicator LED that is. I thought about drilling a hole in the cap plate in the center of the handlebars but it's kinda thick and the hole would probably way out last the i8ndicator. Dunno about drilling a hole in the headlight. It would be nice if I could mount it in the tack or speedo but I don't see that happening.
jer0177
VRCC 32975
Pittsburgh, PA
Re: Where's the best place to mount this?
August 02, 2012, 01:52:41 PM »
What about sealing it up (leaving the LED visible) in something like this and then clamping it beside the riser clamp or somewhere else highly visible? That way if the module croaks, you just unscrew it from wherever it is and there's no hole left behind. You could epoxy or RTV the LED into the 5/16" hole in the mount, maybe even find a nice chrome ring to fill the gap.
http://www.jcmotors.com/p-10555-kuryakyn-universal-1-handlebar-clamp.aspx#.UBroLKPds8A
Fritz The Cat
August 02, 2012, 03:01:39 PM »
Great idea, thanks.
Jeff K
August 02, 2012, 07:39:48 PM »
I put a light to indicate boost in the bar clamp once upon a time. It's not that thick.
jer0177
VRCC 32975
Pittsburgh, PA
August 02, 2012, 07:46:20 PM »
No problem. Those handlebar clamps are pretty handy when you need a hole somewhere and don't want to make a new one.
I've used them for speaker mounts on the Shadow before, and one of them is holding my iPod cradle on the Valk now.
Mr.BubblesVRCCDS0008
August 02, 2012, 07:49:56 PM »
I mounted mine in the panel just right of the tach. Just drilled a hole in the side of the tach bezel so light is not facing straight at you but still very visible while riding.
BnB Tom
Where'd old times go?
Frisco, TX
Reply #6 on:
August 03, 2012, 05:07:20 AM »
Quote from: Mr.BubblesVRCCDS0008 on August 02, 2012, 07:49:56 PM
Yes. The little light is VERY BRIGHT.
So, plan ahead. At night it can be extremely distracting.
Fritz The Cat
Reply #7 on:
August 03, 2012, 08:35:16 AM »
I went with the clamp. Non permanent is good.
Jeff K
Reply #8 on:
August 03, 2012, 01:03:54 PM »
I shoulda just sent you mine. I'm not using it.
Fritz The Cat
Reply #9 on:
August 03, 2012, 03:59:40 PM »
Quote from: Jeff K on August 03, 2012, 01:03:54 PM
LOL, story of my life, a day late and a dollar short.
The handlebar plate on mine is .77 inches thick. It would take some drilling to get through it as it's solid. I do have a drill press but it won't undrill holes so I guess the ring is better.
Chattanooga Mark
Reply #10 on:
August 03, 2012, 04:56:03 PM »
I've had one of those on top my tool box for a couple of years now. Please post a pic of yours once it's installed if you can.
Thank You,
Mark
www.bikersforchrist.org
Fritz The Cat
Reply #11 on:
August 03, 2012, 07:31:06 PM »
Will do.
