February 05, 2026, 06:07:25 PM *
Pages: 1 [2]   Go Down
Author Topic: Valk going to sit awhile  (Read 4891 times)
saddlesore
« Reply #40 on: September 03, 2012, 03:33:02 PM »
Yeah, I broke the whole bowl. I paid $60 for it.  I always had some trouble with a couple of them.  I made a screwdriver specifically for draining the carbs.
Since the winters have been mild enough I manage to take the bike out occasionally anyway. Sometimes the rides get a little long and I have to put fresh fuel and sta-bil in.  Worth it though.
DARE TO BE DIFFERENT
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #41 on: September 03, 2012, 04:08:36 PM »
That's really an exaggeration.
Screws are available at many hardware stores, take one to match the threads to be sure.
The screws most available are socket head cap screws which are a little too long.
You may have to use a washer or two to avoid causing problems. I think the main problem of too long screws are they will punch out through the top of the float bowl base.
The only other possible danger would be to strip the screw holes. The screws that are stock are special soft screws, made to avoid stripping the screw holes in the carburetor.
The replacements are probably grade 5 or higher and so will easily strip the threads of the hole.
He didn't say he had to replace the bowl screws, he said he had to replace the drain screw, which is not a standard screw.
Which reminds me, I had bought an old Honda once. The float bowl drain screw heads were buggered up, so I went down to buy some new ones.  Well.......you just cannot buy replacement drain screws. You need to buy the ENTIRE float bowl assembly!  They were over $50 each about 15 years ago......and I wanted FOUR of them!!  So THAT idea went down the "drain" real fast......... tickedoff
Farther
Quimper Peninsula, WA
« Reply #42 on: September 03, 2012, 06:04:51 PM »
I use 1/2 stabil and 1/2 seafoam.  Reason 1/2 stabil is it is cheaper than seafoam per ounce.
If your looking for cheaper then just use Sta-Bil with no SeaFoam.
~Farther
saddlesore
« Reply #43 on: September 03, 2012, 07:02:05 PM »
Just for clarification....While trying to loosen the drain screw the bottom of the bowl broke off.
Pages: 1 [2]   Go Up
