August 15, 2025, 07:45:48 PM *
Author Topic: Low rumbling noise in engine  (Read 1212 times)
Frankie72
« on: August 13, 2012, 01:56:09 PM »
HI
I just bought a Valkyrie with 53k miles on it. There's a low rumbling sound coming from the engine. When I pull the clutch lever, the noise disappears, when I release the clutch lever, the noise returns. I took it to a bike dealer, but they're not certified Honda mechanics, which they were upfront about. They found rubber and metal shavings in the clutch cover, but that's as far as they would go.
Before I turn it over to a Honda dealer, does anyone have any theories about this noise?
Thanks!
NITRO
Eau Claire, WI
« Reply #1 on: August 13, 2012, 02:05:08 PM »
Did you see the reply about your clutch rivets on the VOAI? Most likely that is your problem.
When in doubt, ride.
« Reply #2 on: August 13, 2012, 02:17:46 PM »
HI
Thanks!
If this only happenes in neutral....dont take it to the mechanic...its perectly normal, they all do it
OK, I missed the part about the stuff they found inside......as I have never taken a cover off before I dont know if thats normal wear (it doesnt sound normal) but if you clean that out and it runs fine, Id check it again in a few thousand miles....the noise you described is normal in neutral
« Last Edit: August 13, 2012, 02:21:35 PM by Chrisj CMA » Logged
F6Dave
« Reply #3 on: August 13, 2012, 02:33:06 PM »
I agree with Chrisj CMA - that sounds like a normal noise.  But I don't know where that rubber and metal would come from.  Maybe the seal around the release rod?  When I changed my clutch last year the only thing I found were a few sheared rivets.
« Reply #4 on: August 13, 2012, 03:20:10 PM »
Yep,, like said,, that noise is normal.. Does the clutch operate smoothly ?? It should also engage and release smoothly..
Frankie72
« Reply #5 on: August 13, 2012, 04:19:04 PM »
The clutch does operate smoothly.
« Reply #6 on: August 13, 2012, 04:24:26 PM »
well, if the noise was just in neutral.........ride it.  just pay attention
Frankie72
« Reply #7 on: August 13, 2012, 07:52:29 PM »
The engine noise is ever present, not just in neutral.  It abates only when the clutch lever is pulled. The clutch cover had metal shavings and rubber shavings in it.  This can't be normal.
« Last Edit: August 14, 2012, 12:56:39 AM by Frankie72 » Logged
« Reply #8 on: August 17, 2012, 09:14:30 AM »
It's not normal.
Rubber is from a seal. Could be remnants from an older operation to make repairs.
Metal shavings should be checked for steel or aluminum. Size and quantity of shavings is important in deciding what to do.
The cover should have been checked along with any other areas that need close attention and viewing. The shop should have done that.
What did the PO have to add to the inquiry?
