February 05, 2026, 06:07:26 PM
carb sync
Topic: carb sync (Read 1749 times)
Mike in AR
Redfield, Arkansas 72132
carb sync
August 14, 2012, 06:13:21 PM »
While at Inzane this year, I had Big BF do a tune-up on my '97 bumble bee. This also included a carb sync. However, I forgot to tell him that I had put 38 slow jets in the carbs. How big a difference will this be in the way the bike runs? And if so, what can I do to correct the the problem? I should have remembered to tell Big BF about the change, but just wasn't thinking about it.(Nothing new about the not thinking part.lol)
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
old grouch
Colorado Springs, CO
Re: carb sync
August 14, 2012, 06:29:23 PM »
Don't think the 38s will have any effect on a carb synch. It only balances the flow rate of the throttles.
09/11/01 NEVER FORGET!
Mike in AR
Re: carb sync
August 14, 2012, 07:16:47 PM »
Thank you old grouch, that is the good news. I would feel pretty dumb for asking the question, except that when it comes to mechanicing(sp), I know very little. But, I am learning, little by little. Thank you again.
Mike in AR
Re: carb sync
August 15, 2012, 03:58:05 AM »
The 38s would affect the pilot settings which should have been taken care of at that time.. It'll have nothing to do with the sync..
Mike in AR
Re: carb sync
August 15, 2012, 04:25:55 AM »
Thanks Patrick. Old dog here trying to learn some new stuff. Not always easy.
BigBF
Text message at 602-332-4872
Phx AZ
Re: carb sync
September 04, 2012, 03:08:04 AM »
Mike,
No worry about it.
It only run thru air/fuel mixer and go thru the pilot screws.
Carb sync is to have all 6 carb running equal for air flow thru butterfly.
BigBF
