For the last seven years, I have used this Tech Board to an amazing degree. The wealth of knowledge that so many of you have so kindly made available has assisted me greatly with troubleshooting, modifying, and maintaining my first interstate. I cannot thank y'all enough.
I certainly have taken more than I have contributed. It is simply not my nature to post a lot; like many, I usually search and find what I'm looking for. Until today, I have not had anything that might be considered "new" information to contribute. I'll let y'all be the judge.
Here's the situation. Recently bought another interstate to make a solo ride. With the trunk permanently removed now (and no saddle bag guard rails installed or intended), I needed a new place to mount the antenna. Searches of the board revealed a method that was not compatible with the truck stacks currently installed (insufficient clearance). I also could not find any after market products that would work.
Here's what I came up with:
There's not much to it. Drilled three holes in a 1" square tube (aluminum) that was cut to length and polished. Added a couple end caps and attached it to the band for the right saddle bag stay (replaced the original flange bolts with longer ones).
We'll have to see if the heat from the exhaust causes any damage to the cable.
I'm thinking about making a second one for the left side (flag holder maybe?)
