I found this with an internet search:
Can you mix motor oil viscosities?
In:Oil and Oil Filters [Edit categories]
Answer:
Short Answer is Yes but don't mix brands
Long answers
From the Chevron.com site:
"Can I mix different viscosity grades of motor oils?"
"Yes. It is always advisable to not mix motor oil brands, however, different viscosity grades of the same brand motor oil are compatible. Be aware that mixing viscosity grades will turn out a product that is different in viscosity than either what was originally in the engine or what was added."
From Shell.ca:
"If you mix viscosity grades such as a 5W30 low-viscosity oil and a 10W40 higher-viscosity oil, it is reasonable to expect that the resulting product will have viscosity characteristics which are thicker than the 5W30, but thinner than the 10W40. This change does not reflect incompatibility - it's simply a re-balancing of the viscosity characteristics. In all other ways, the product should work as expected. But there's absolutely no danger about incompatibility resulting from mixing engine oils," Miller says. "We've tested all of our grades and brands, and we haven't observed any problems."
From Mobil1.com:
"For our customers to choose a viscosity grade, we recommend they follow the engine manufacturer's recommendations as indicated in their owner's manual. There is no need to mix two Mobil 1 viscosity grades when one will do; however, we see no problem mixing different SAE grades of Mobil 1 Tri-Synthetic series motor oils."
Read more:
http://wiki.answers.com/Q/Can_you_mix_motor_oil_viscosities#ixzz23r5U7RgeOil is one of the few things that I am very picky about and will not cut corners on.
I wouldn't mix viscosities or brands if I didn't absolutely have to, But it would appear that it is OK.
