November 25, 2025, 07:01:13 AM *
Author Topic: need tall windscreen  (Read 1014 times)
tjbuet
« on: August 19, 2012, 05:10:32 AM »
Hi
Who makes a good tall windshield? I have a 98 tourer with the stock shield. It's 19" above the headlight. To short for me. Are taller ones available? I have a stock seat, but will be going to the Ultimate King Big boy, which I understand will place me even higher then I am now.
Terry
« Reply #1 on: August 19, 2012, 05:20:01 AM »
Clear view will build you one as long as you want.  Hoser  cooldude
http://www.clearviewshields.com/
« Reply #2 on: August 19, 2012, 06:13:17 AM »
Clearview is a good source for replacement shields.  Gives you stock dimensions.
21.5" length:  measured from the top of the headlight cutout to the top of the shield. Don't know how wide OE is (26"?), but their OE replacement is one inch wider. ($203 and up for taller) (generally thicker than stock and Clearview is Lucite/plastic, and I think OE is lexan) (you can get an adjustable vent for more money)
http://clearviewshields.com/shop/product.php?id=33
Stock shield from HDL is:
(reuse the Honda mounts, whether for OE or aftermarket)
http://www.hdlparts.com/fiche_section_detail.asp?section=2137059&category=Motorcycles&make=HONDA&year=1997&fveh=124889
Another aftermarket maker, also plastic. ($279)
http://www.ceebaileys.com/honda/valkyriews.html
The best Lexan you can get.  ($330)  (supposedly can be scrubbed with steel wool and not scratch)
http://www.f4customs.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=GLNTD-HVN57KAPANP&Category_Code=VALKTOUR
HDL has a bunch of others, but none are better, and these you have to buy the mounts as well (I think).
http://www.hondadirectlineofshadyside.com/stores/byProduct.asp?prd=Windshields&str=2&ID=553003918
tjbuet
« Reply #3 on: August 19, 2012, 08:07:31 AM »
Thanks.   I'll check the Clearview out.
Terry
valkyriemc
NE Florida
« Reply #4 on: August 19, 2012, 12:32:36 PM »
If not clearview try Tulsa. Very happy with mine.
Veteran USN '70-'76
