November 25, 2025, 07:23:57 PM *
Author Topic: Clearview Tourer windshield  (Read 2351 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: August 20, 2012, 03:05:38 AM »
Those of you who have replaced your stock "Tourer" windshield with the Clearview, were you able to use the same bolts through the chrome or did you need to go with longer bolts?
« Last Edit: August 20, 2012, 03:07:21 AM by Tundra » Logged
« Reply #1 on: August 20, 2012, 03:44:50 AM »
I remember having to scrounge for longer bolts when I added the thickness of the
hoppe fairing, but not the clearview...
« Reply #2 on: August 20, 2012, 05:11:43 AM »
I used the oem bolts. probly would need longer if you have a windshield storage pouch.  Hoser
Foozle
Lexington, KY, USA
« Reply #3 on: August 20, 2012, 05:44:50 AM »
If you're simply doing a direct swap, all the OEM hardware should work.  I can't recall any issues when I installed the Clearview.  Terry
sheets
Jct Rte 299 & 96, Calif.
« Reply #4 on: August 20, 2012, 12:47:52 PM »
Get some half-inch longer bolts to assemble the trim hardware on the Clearview shield. Once its in place remove one bolt at a time and replace with the short chrome OEM bolt.
donaldcc
Palm Desert, CA
« Reply #5 on: August 20, 2012, 04:04:11 PM »
  i have 22.5 " Clearview that was on bike when I got it.  Has vent and i like the shield a lot.  Here is quote from their website that seems to indicate it fits on stock frame.
Features:
• Clearview Shields has been Handcrafting Shields in the USA for Over 20 Years
• Top Rated by Riders Around the World in Performance, Quality, Fit and Finish
• Premium High Impact Acrylic Blend Material Exceeds Industry & DOT Standards
• UV Inhibitors Extend Shield Life & Provide Protection for the Dash and Acc.
• 3/16" (.187) Thick Material is More Rigid than the Stock Shield
• Ready to Mount to your Honda Brackets (we do not offer any brackets)
• Designed with the Same Shape and Contour as the Stock Honda Shield
• 6 Different Heights Available to Tailor the Shield Height to Your Height
• 1" Added Width on GT Models for Increased Protection
• Shipped with a Clear Protective Film that allows Installation and Testing
• Can be Polished, Buffed, and is Safe to use Rain-X Original Clear Formula
Note:  These Shields are Designed to Mount to the OEM Honda Brackets.
* Clearview Shields are designed as "replacement" windshields. We do not offer any brackets/braces/framing or any other hardware. Our windshields are pre-drilled and pre-contoured to mount to your existing OEM setup.
Don
CRG
« Reply #6 on: April 01, 2013, 06:42:05 PM »
How is the vent working?
« Reply #7 on: April 01, 2013, 07:23:53 PM »
I have the 22.5 Smoked vented screen.  Used OEM bolts.  Love the vent, it really helps with air flow dynamics especially when riding in windy conditions.
mmurffy03
03 standard
toms river new jersey
« Reply #8 on: April 01, 2013, 07:57:09 PM »
I have the shortest windshield they make with the vent and had no problem at all with the installation I started in the middle and worked out from there
papa bear
« Reply #9 on: April 02, 2013, 07:42:08 AM »
I put a Clearview on my '98 Valk Tour and had no problems with any bolts. It fit just like the factory windsheild.
« Reply #10 on: April 02, 2013, 08:25:47 AM »
No problems with the swap!
My rides:
BobB
« Reply #11 on: April 02, 2013, 03:34:33 PM »
The 6mm-1 bolts and acorn nuts are used on the windshield.  The nut can accept the bolt turned in about 7 revolutions or going in 7mm.  I would use bolts that require no less than 4 revolutions going into each nut, 6 revolutions would be ideal.  Use loctite.  I'm thankful for my pedestal grinder to get bolts, etc the right length.   Smiley
I have replaced my windshield once and next time will try the Clearview.
I did exchange the windshield nuts to chrome high-crown acorn nuts and put those on the front of the windshield (bolts go in the back and are hidden by windshield bags).  These nuts provide somewhat of a sinister look.   Cool
Farther
Quimper Peninsula, WA
« Reply #12 on: April 02, 2013, 03:54:12 PM »
I never thought of acorn nuts as being more "sinister" than the stock washer/hexhead chrome bolts.
~Farther
BobB
« Reply #13 on: April 02, 2013, 04:10:58 PM »
The high crown acorn nuts are taller and somewhat pointed.  See: www.chromebolt.com
I have almost 40 of these around my '98 Tourer.
