February 05, 2026, 06:07:20 PM *
Author Topic: Kickstand switch- how hard to replace  (Read 1653 times)
Tx Bohemian
Victoria, Tx
« on: August 22, 2012, 09:44:26 AM »
Looking in a Clymer manual it looks like the connection for this is by the battery and it states to remove the wire from the hooks.
I take it these are on the frame somewhere?
How long is the pigtail on the switch?
Is the replacement "cut and dry" or is there a trick or two I should know?
Switch should be here Friday, just trying to get a heads up...
Al
« Reply #1 on: August 23, 2012, 08:13:07 AM »
"Cut and dry"
Very dirty if you've been lubricating the kickstand as you should.
« Reply #2 on: August 23, 2012, 09:51:04 AM »
"Cut and dry"
very dirty?   Not if you clean the thing regularly.......dirt hs no place on my Valkyrie underneath or behind the ears......nowhere especially moving parts like the kickstand and spring....clean as a whistle
vanagon40
Greenwood, IN
« Reply #3 on: August 23, 2012, 10:17:53 AM »
. . . . dirt hs no place on my Valkyrie underneath or behind the ears . . . .
But most of us don't park in the living room.
Cattman
Franklin, IN
« Reply #4 on: August 23, 2012, 10:29:27 AM »
Mine was in front of the bottom of the battery box and took a pair of right angle needle nose pliars, most of a 12 pk of Yeungling and some cut up hands to get the !@#$ wiring socket apart and back together.  uglystupid2
9Ball
« Reply #5 on: August 23, 2012, 12:57:46 PM »
Moving the modules out of the way to access the plug helps....just make sure you remember how they all "nest" together and their proper orientation (especially the bank angle sensor).  I replaced mine a few years ago and it is a bit tight for large hands to get to the plug.
Also, pay close attention to the way the switch is bolted/positioned and you will be fine.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #6 on: August 23, 2012, 06:33:19 PM »
[quote autho cooldude
"Cut and dry"
+1  cooldude
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
