November 25, 2025, 07:01:07 AM
ELECTRICAL CONNECTION POWER PLATE
Topic: ELECTRICAL CONNECTION POWER PLATE (Read 1142 times)
bikerboy1951
Grand Forks, ND
August 23, 2012, 02:36:30 PM »
Has anyone mounted the Electrical Connection power plate and ground block. If so, where did you mount them. The space behind the battery box is already taken up by the brain for the MCCruise control.
Any ideas or pics are appreciated.
Thanks.
Brad
PhredValk
Edmonton, Alberta, Canada
Re: ELECTRICAL CONNECTION POWER PLATE
August 24, 2012, 12:02:28 AM »
Standard, Tourer, IS? Lots of options depending on what you have to work on. After market faring? Bags?
Fred.
VRCCDS0237
bikerboy1951
Grand Forks, ND
August 24, 2012, 03:03:52 AM »
The bike is an '01 standard. It has the Hondaline windshield, Boss Bags, MCCruise and BigBF horns.
The area around the battery box is pretty crowded with the MCCruise brain for the cruise, the relay for the horns and the wiring protector for the trailer filling the area.
Brad
9Ball
August 24, 2012, 04:37:46 AM »
under/behind a side cover might work for you. My fuse block is behind the RH side cover and hinged to allow access to the starter relay, etc. This also allows you to tap into the 5A accessory leads for switched power to the relay(s).
Last Edit: August 24, 2012, 04:39:26 AM by jrhorton
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
=> InZane XXV
