August 15, 2025, 05:09:52 PM
Cobra Light bar issue
Topic: Cobra Light bar issue (Read 852 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
August 25, 2012, 02:35:13 PM »
Problem is both light s do not light up. I have power at the switch on the right arm and the switch works properly. Any thoughts? Both lights stopped working.
Dropbox
is a neat app I found that I use to store files and pictures of my Valk.
Madmike
Campbell River BC, Canada
Re: Cobra Light bar issue
August 25, 2012, 02:49:33 PM »
check the ground.....
Sam Shlitz
SoCal
August 25, 2012, 04:07:42 PM »
Did you check the power from the switch to the lamps? I recently had the same problem and it was the switch. Ordered a new switch from Cobra and the problem was fixed.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
August 25, 2012, 04:10:19 PM »
It was actually a short in the hot wire.
Dropbox
Madmike
August 27, 2012, 05:07:04 PM »
did the fuse pop??
Toledo Mark
Formerly Zeus661
Rossford, Ohio
August 27, 2012, 06:39:37 PM »
Just a bad connection.
Dropbox
=> InZane XXV
