August 15, 2025, 07:45:57 PM *
Author Topic: Removing Fuel Tank??  (Read 1214 times)
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
« on: August 25, 2012, 05:20:03 PM »
Hey All...
  Just wondering if anybody knows of, or has a link to, a detailed step by step instructions for removing the fuel tank?
  I have installed the V-Stacks on my 98 Standard, (looks amazing!)and it definitely needs the 1/2 inch spacer put in. No problem with that. I thought I might need it and went ahead and ordered it and the longer bolt.
  I was reading the PDF on BigBF's site for the Spacer Mod, for installing the rubber strips on the underside of the tank, to return it to the 4 points of contact.
  Being a newbie to bikes, after 30 years, I have no idea where to start on removing the tank.
I've got the front and rear bolts out, now what. I figure on siphoning out the most af the gas, but how many fuel lines are under there. Are they hard to get to? Anything I should watch out for?
  I can follow directions pretty well. I'm not to keen on just rolling up my sleeves, digging in, and hoping I don't find any surprises.
  Any instructions, or links to instructions would be greatly appreciated!
« Last Edit: August 25, 2012, 05:54:39 PM by miscott » Logged
Bone
« Reply #1 on: August 25, 2012, 05:39:21 PM »
Scroll up on the page.
Click on Shoptalk.
Right side of that page look for and click fuel tank removal.
« Reply #2 on: August 25, 2012, 05:41:41 PM »
Also on Carl Kulow's Valkyrie Maintenance Guide.  Here.....
http://www.rattlebars.com/valkfaq/valkmaintenanceguide.html
miscott
So. Central Kansas
« Reply #3 on: August 25, 2012, 05:54:01 PM »
A Big Thanks!
That's what I was lookin` for!
I had checked the Shop Talk Page, but missed that one!   tickedoff
Thanks for the links! You guys are great! cooldude
Now I can roll up my sleeves and dig in!
« Last Edit: August 25, 2012, 05:56:19 PM by miscott » Logged
« Reply #4 on: August 25, 2012, 06:01:49 PM »
Getting it off and on aint no big deal.  Cheesy BUT if you have old fat arthritic fingers then putting the hoses back on is a whole nuther kettle of fish.   crazy2 Ah well you should be allright.  cooldude RIDE SAFE.
pacowboy78
Towanda, PA
« Reply #5 on: August 26, 2012, 04:20:57 AM »
The other thing I'd do is pick up a service manual.  Between that and this board, There's probably no stone left unturned.  I know both have been a tremendous help to me.
« Reply #6 on: August 26, 2012, 02:04:47 PM »
  Service manual is a good idea.  Cool But keep in mind it's NOT 100% correct all the time. I have a loose leaf binder with short cuts from this board that i have printed up and find myself reffering to it quite often.  cooldude RIDE SAFE.
Davemn
Minnetrista, Minnesota
« Reply #7 on: August 26, 2012, 02:23:53 PM »
Make sure you cover the tank to protect it in case you drop a heavy ratchet on it.
« Reply #8 on: August 26, 2012, 05:01:17 PM »
You can download the service manual at the site shown below:
http://www.valkyrienorway.com/download.html
My rides:
shortleg
maryland
« Reply #9 on: August 27, 2012, 07:29:03 AM »
  One tool you will find useful is a long pair of needle nose pliers with
a right angle in the needle end also tie a piece of string to the clamp
on the gas line. It can slip down to the other end and be bit#$ to
get to.
         Shortleg[Dave]
