November 25, 2025, 04:21:03 AM *
Author Topic: Kuryakyn Neck Cover  (Read 983 times)
1500Rider
« on: August 31, 2012, 08:25:55 PM »
Work on my '97 Tourer rebuild continues and I was contemplating adding some more chrome to the bike. One item I was looking at is the Kuryakyn Neck Cover. I have installed the Aeromach Velocity Stacks along with the spacer for lifting the front of the gas tank. I was curious if the neck cover would still fit with the front of the tank raised. Anybody out there with the neck cover and velocity stacks?
Also, I just read somewhere that the chrome engine hangers that are currently available (replicas of the original Hondaline ones) do not fit if the tank is raised. I wasn't sure if this was accurate or not as I couldn't see how it would make a difference. If anybody has any experience with either of these, please chime in – I'd hate to go out and spend the money only to discover I can't use the accessory.
1990 Honda VFR750F
1997 Honda Valkyrie GL1500 Tourer
1998 Honda Gold Wing GL1500 SE
mmurffy03
03 standard
toms river new jersey
« Reply #1 on: August 31, 2012, 09:33:16 PM »
i have an 03 valk with stacks the shim bigbf makes and the aftermarket engine hangers and the kuryakyn neck cover installed i put clear silicone under the shim to keep it in place when im installing the tank but it all fits with no problem
1500Rider
« Reply #2 on: August 31, 2012, 10:04:54 PM »
Thanks for the response. Just what I needed to know.
1990 Honda VFR750F
Aquaman
Clinton Township,MI
« Reply #3 on: September 01, 2012, 04:48:33 AM »
I have a 99 standard. I had to cut away a lot of the plastic cover & it still rubs!
