February 05, 2026, 06:03:08 PM
de smog is red eye the best
Topic: de smog is red eye the best (Read 1992 times)
mmurffy03
03 standard
toms river new jersey
September 02, 2012, 05:14:40 PM »
is the red eye desmog kit the shiney one the best you can get and does it work with the kuryakyn plug cover set ?
X Ring
VRCC #27389, VRCCDS #204
Re: de smog is red eye the best
September 02, 2012, 05:25:27 PM »
Quote from: mmurffy03 on September 02, 2012, 05:14:40 PM
Made my own kit for less than $10. All I needed were freeze plugs, some sheet aluminum to make block off plates for the air system on the under side of the engine and vacuum caps.
Marty
art
Grants Pass,Or
Grants Pass,Or
September 02, 2012, 08:13:31 PM »
I did the exact thing about three years ago.Way to go
September 03, 2012, 03:54:32 AM »
Go in Shop talk or archives and look at Normands [Quexpress] article.. Its the best on this subject..
September 03, 2012, 04:06:38 AM »
I did it the Quexpress way too... here's the plate I made for the bottom, my tops are
the OEM Chrome nubs with the pipes cut off, filled with epoxy, held down with the
original holder-downers... never a problem...
I like the way the top plugs in the Red Eye kit look, and work...
Thunderbolt
Worthington Springs FL.
September 03, 2012, 05:07:01 AM »
Four 9/16" freeze plugs, some exhaust gasket material and some of the two part epoxy that you see in the tubes at the auto parts store that look gray but have a black center kinda like a tootsie roll. Take all the smog stuff off, tap the freeze plugs in with a small 1/4" extension on the top four. Make sure the socket is quite a bit smaller than the freeze plug or it will get trapped when you drive it in. For the bottom two, cut the tubes off the OEM parts and fill them with two part epoxy and put a piece of exhaust gasket underneath. Remove the pair valves and screw a bolt from your junk box that is snug into the hole left in the bottom of the airbox. Put caps on #3 and #4 vacuum ports.
Blaze
Usa
Reply #6 on:
September 07, 2012, 06:03:59 PM »
The cheapest, easiest way to do it.
http://www.valkyrieriders.com/shoptalk/desmog.htm
