February 05, 2026, 06:07:31 PM
creaking sound
Topic: creaking sound (Read 1197 times)
slider
mulberry arkansas
creaking sound
September 04, 2012, 06:13:55 AM »
stock 97 standard with stock shocks,when i press down on pass seat the shocks emit a creaking sound that is pretty loud after i press down on the seat 2-3 times the sound stops,but after a wait of 30 seconds its back.. i used rubber lube n the upper bushings(replaced 1000 miles ago) as well as the lower with no relief..Anyone have any ideas on what to do??thanks in advance
a proud navy veteran
Re: creaking sound
September 04, 2012, 06:41:32 AM »
stop pressing down on the seat
Re: creaking sound
September 04, 2012, 06:53:10 AM »
Squeaking is probably from seat mounts... mine do it. Remove seat and dab grease or lube on the mounts. Or lube front and wrap little elect tape on rear stab mount.
Michvalk
Remus, Mi
Re: creaking sound
September 04, 2012, 07:18:54 AM »
Or, it could be the shock creaking. You could put your hand on the shocks and see if you can feel the vibration through the shock
