January 28, 2026, 08:04:57 PM *
Author Topic: fuse block  (Read 1967 times)
Merle
« on: June 07, 2009, 05:40:08 PM »
where do I get the switched source of power to trigger my relay for my fuse block.  I bought the electrical connection setup with block and relay,  just can't find the switched accessory lead for the relay.
« Reply #1 on: June 07, 2009, 05:49:47 PM »
It's in the right side cover on a standard, should be a solid Dark green wire and a light green and red stripe wire with (I believe - took mine off) female bullet connectors and clear plastic insulators, That is unless someone has already wired an accessory to them.
