February 05, 2026, 07:37:41 PM *
Author Topic: pinion gear needle bearing replacement  (Read 1644 times)
Sonny
Holt, Mo.
« on: September 05, 2012, 06:26:32 PM »
I have the bearing on order. Has anyone done this. What kind of tool did you use to get it out?
Bikers for Babies is coming soon to KC have to be done before then.
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
lee
Northeast Tennessee
« Reply #1 on: September 05, 2012, 07:29:00 PM »
Dental tools, the kind Dentist use.
Time is not what is taken but what remains.
C. Drewry
lee
Northeast Tennessee
« Reply #2 on: September 06, 2012, 05:43:39 AM »
http://www.hdlparts.com/fiche_section_detail.asp?section=2136868&category=Motorcycles&make=HONDA&year=1998&fveh=124890
In the parts detail,  1 is the needle bearing.  And 4 is the keeper I am referring to which has to be removed before you can get the
bearing out.  Are we on the same page here?
C. Drewry
« Reply #3 on: September 06, 2012, 06:51:39 AM »
I cannot imagine that bearing going bad!
What were the circumstances?
The pinion must necessarily be replaced also!
Sonny
Holt, Mo.
« Reply #4 on: September 06, 2012, 09:44:51 AM »
Ring and pinion are new. Replacing the axle, cup, axle seal and pinion bearings also. The ring in the bottom of the bearing is not excessable that I can see ???
2003 VTX, 1800C
« Reply #5 on: September 06, 2012, 02:25:59 PM »
I feel that you are replacing things that do not need replacing.
Namely the bearings.
The bearings for the most part are easily inspected for damage.  If they are Ok, they are good to use.
Quite a bit of unnecessary expense.
A good and careful cleaning of the bearings is all that should be required.
lee
Northeast Tennessee
« Reply #6 on: September 06, 2012, 05:16:07 PM »
There is a hole in the side of the bearing housing.  Thats the only axcess there is to the wire keeper ring.
If you don't feel like you can do it then use the old bearing.  Just clean it out good  and use it.
But take my word for it you can not get the bearing out without first removing the wire keeper and that
has to be done through the small hole in the housing.  I was not joking when I said you need DENTAL TOOLS.
C. Drewry
« Reply #7 on: September 07, 2012, 07:29:05 AM »
Additionally that hole is there for lubricating purposes.
Sonny
Holt, Mo.
« Reply #8 on: September 09, 2012, 09:18:18 PM »
I see the keeper in the hole. You can only push on it a little. Does not move but a very small amount.
It does not seem like its enough to help remove the bearing. If I can't get it out I'll have to take it up to the Honda shop. Hope I get someone who actually knows what they are doing.
2003 VTX, 1800C
Sonny
Holt, Mo.
« Reply #9 on: September 17, 2012, 09:24:44 PM »
Still have not been able to get bearing out. But then again the new one hasn't shown up yet anyway. Have a local machine shop I'm going to take it buy there and see if they can take it out and put the other one in.
2003 VTX, 1800C
