February 05, 2026, 06:07:37 PM *
Author Topic: Snap, Crackel, Pop  (Read 1640 times)
Rudy
« on: September 05, 2012, 07:10:59 PM »
I have a 99' Valk that's has been a garage queen. I'm wanting to get back on the road with it so I had it out a few times this past month and it just popped and backfired a bunch when I let off the throttle. The throttle was also very sluggish, especially at low rpm's. So, after a lot of research on this site it seemed like the slow jets and vacuum lines might be the culprit. I wrenched on it this past weekend and thought I'd share what I have found.
Problems:
A) Vacuum lines had three pinholes in them
B) The clamps on the rubber boots conecting the intakes and the carbs were all loose. (3 per carb, 18 total)
C) The gasket material sealing the rubber seals conecting the air box to the carbs were all dry rotted and pealing.
D) The carb bowls had silt in them and the gas was orange in color.
E) My choke was getting stuck open on the right side bank of carbs.
I addressed all of the above issues, put it back together, added fresh gas, Berryman's Chem Tool carb cleaner, and took it for a spin. It now idles smooth, throttle response is great, and it flat out takes off like a fighter jet!   coolsmiley coolsmiley
But............  tickedoff I still have a little popping at let off at 3000 rpm's.  Not much but it's there. I have had the exhaust on and off twice with this bike so I ordered some new exhaust gaskets and going to replace the old one's and see what happens.
Bigwolf
Cookeville, TN
« Reply #1 on: September 06, 2012, 12:07:39 AM »
Just in case the exhaust gaskets don't solve the remaining decel pop.  Did you check the cut valves for proper operation?  Also, were those 6 short (2 and 3/4 inch long) vacuum hoses to the cut valves among the vacuum lines you checked/replaced?  If not, then these could be the reason for the remaining bit of decel popping.
It sounds like you have taken care of the most common causes of decel pop.  These last few things should eliminate it unless you have aftermarket pipes like 6 into 6.
Bigwolf
Thunderbolt
Worthington Springs FL.
« Reply #2 on: September 06, 2012, 03:57:55 AM »
I second the small cut valve lines.  Each carb has one and they are only about 2 inches long and are the same vacuum line as the others that you found holes in.  If you take one off you will see cracks in each end once you inspect them closely.
custom1
01 Interstate
SW Pa
« Reply #3 on: September 06, 2012, 10:08:05 AM »
Check the o-rings at the base of each intake runner. Mine are seeping, and on the list for this winter.
John
