February 05, 2026, 07:37:44 PM *
Author Topic: shifting  (Read 3465 times)
TKM
Brockville Ontario
« on: September 09, 2012, 02:55:52 AM »
this is the third season with my Valk ,love the bike ,lots of power .Shifts up and down like an old truck , what can i do to inprove
78 Gl 1000
79 GL 1000
76 GL 1000
82 GL 1100
99 Valkyrie
74 Triumph TR6
« Reply #1 on: September 09, 2012, 04:02:28 AM »
increase rpm...decrease throttle back prior to shift
« Reply #2 on: September 09, 2012, 04:13:56 AM »
Square cut gears contribute greatly to the bike's reliability and longevity.
TKM
Brockville Ontario
« Reply #3 on: September 09, 2012, 04:56:09 AM »
Ok I'll give that a try , trying to get through all the gears without a clunk , clang or a grind has become a fixation which makes it that much  worse
78 Gl 1000
79 GL 1000
76 GL 1000
82 GL 1100
99 Valkyrie
74 Triumph TR6
Daniel Meyer
The State of confusion.
« Reply #4 on: September 09, 2012, 06:23:17 AM »
Preload the shifter on upshift.
CUAgain,
Daniel Meyer
BonS
Blue Springs, MO
« Reply #5 on: September 09, 2012, 06:28:31 AM »
+10  cooldude
« Reply #6 on: September 09, 2012, 09:37:40 AM »
Several folks have gone to a good synthetic oil which helps a bunch.
« Reply #7 on: September 09, 2012, 11:12:26 AM »
You are not riding a Ferrari, so BANG the gear into the next one and forget about it.
Chet's heel toe shifter is a good fix for that problem.
« Reply #8 on: September 09, 2012, 11:46:02 AM »
You needz lotsa AUTHORITY when you shift these beasts. Be firm with her and she will respect you more. Be timid on shifting-you already know.  2funny RIDE SAFE.
« Reply #9 on: September 09, 2012, 11:58:42 AM »
I think the best suggestion is to try a better oil, one that would facilitate better shifting.
And it would be good to inspect the shifter linkage for looseness and clearance from obstruction.
« Reply #10 on: September 09, 2012, 01:35:31 PM »
OK I'll bite, how does one preload the shifter?  ???
My rides:
Buda
Buda IL
« Reply #11 on: September 09, 2012, 01:42:23 PM »
Put a bit of pressure on the shifter with your foot before you shift.
97 Valkyrie
33344
« Reply #12 on: September 09, 2012, 04:19:51 PM »
Very much like taking the slack out of a trigger before pulling it.
97ValkSteve
Jawjuh
« Reply #13 on: September 09, 2012, 04:44:03 PM »
It's funny.  I didn't notice how clunky she was to shift until I put stock pipes on in place of my 2 brothers this Spring. In my mind I actually thought it shifted smoothly and quietly.   Plus, now you can really hear all the other little noises she makes which I kind of like.
Occasionally, I get the perfect clunkless shift by doing the "preloading" and shifting just at the right RPM but then the next time it doesn't work so basically I don't really try much anymore and just enjoy the ride.
Also, I briefly tried the clutchless shifting mentioned in another recent thread and sometimes it would shift real smoothly and others it was pretty awful so I gave up on THAT technique quickly.  Good luck and enjoy!  Steve
Sigrún
Lewisville, TX
« Reply #14 on: September 09, 2012, 06:01:00 PM »
Almost precisely like that. Also I've learned that the faster you shift, the more the lady likes it  cooldude
Lift the shifter until the play is all gone and you can feel the shifter starting to touch the ratchet, rev up to your shifting RPM ( whatever that might be on that situation ), pull the clutch just about halfway there, drop the throttle just a tad and shift like the beelzebub is right behind you. The more you think about it, the more you're likely to botch it up, but once you get it down to muscle memory, you'll be well and truly surpised how smoothly she can shift up......
It'll take some practice and a learning curve but it can be done. And it's worth it.
IBA #54465
« Reply #15 on: September 09, 2012, 07:37:34 PM »
speaking of shifting,  I'm pretty sure this is normal, but does the foot shifter jiggle a tad (seems loose but is not) and that is how it is suppose to be, with a tad bit of slop/jiggle room in the shifter rod?
On the same note,  has anyone had troubles ONLY when the bike is in extreme heat and revved and road hard at lower speeds a lot in town traffic mostly, had trouble downshifting or upshifting from 1st to 2nd or 2nd to 1st without getting caught in between which is neutral?  Same intense heat and  several low speed shifting in town traffic and I sometimes find it hard to get the bike out of neutral especially into 1st gear like it won't go.  I have to slam it hard from neutral into 1st gear and even sometimes that does not work, like the heat causes the gears to not go smoothly ONLY out of neutral/1st gear.
9Ball
« Reply #16 on: September 10, 2012, 04:08:02 AM »
Also, make sure to flush and bleed the clutch master cylinder.  Inspect the clutch lever for worn or sticky operation and fix accordingly.  It helps to have everything up to operating standards..
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #17 on: September 10, 2012, 05:12:20 AM »
I've never experienced what you've described even on 100 degree days. Sounds like a serious problem. I would think that slamming a bike in gear is eventually going to result in a bent shifting fork(s).
My rides:
« Reply #18 on: September 10, 2012, 06:31:55 AM »
As someone said earlier, change the oil.    I've used nothing but Automobile Mobil 1 - 15/50W I think it is.     My case of oil is at the shop, and the kid is out on the lake somewhere in the boat, and it is 11 miles for me one way, so just take my guess unless I post it differently later.
Daniel Meyer
« Reply #19 on: September 10, 2012, 06:41:50 AM »
+1 on this for the heat related issue...I've seen this behavior in high heat when the clutch fluid is old/saturated.
CUAgain,
Daniel Meyer
Tx Bohemian
Victoria, Tx
« Reply #20 on: September 10, 2012, 08:06:28 AM »
...Also I've learned that the faster you shift, the more the lady likes it...
I've noticed this too.
If I "speed shift" I smoothly run through the gears like a pro racer, but trying to "normal" shift seems like I've lost all coordination between my feet and hands!!
Al
whitestroke
San Pedro, Ca.
« Reply #21 on: September 11, 2012, 01:13:06 PM »
cooldude++++
cooldude+++++
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
« Reply #22 on: September 12, 2012, 11:13:28 PM »
Doubt it is the oil since only about 4,000 miles on Amsoil 10w-40 full synthetic cycle oil this year of riding since March of this year.  I'm not slamming as hard as I can on the foot shifter, but pretty darn hard.  LIke I said,  it eventually goes out of neutral into 1st or 2nd, just that it gets stuck or should I say hung up in neutral more than I think is normal.  Clutch fluid was changed 3 seasons ago and about 8K miles also.
« Reply #23 on: September 13, 2012, 06:31:51 AM »
Without trying to perpetuate the hijacking of TkM's thread, it sounds like to me you are not using the stock shifter setup but rather some aftermarket "heel/toe shifter mechanism and therefore I feel, there is where the problems lay.
Blackduck
West Australia
« Reply #24 on: September 13, 2012, 09:11:13 AM »
A lot of interesting replies.
We all know the Valk likes shifting better with a few rev's on it, Granny gearchanges are hard to get smooth.
Another thing to consider is what is your idle RPM and does it increase when the bike warms up?
Higher idle RPM will definitely cause harsh shiftling, partically if moving in and out of neutral.
Cheers Steve
