January 28, 2026, 09:40:18 PM
Wiring question-rear speakers
Topic: Wiring question-rear speakers (Read 2459 times)
tbone
Bradford, il
June 08, 2009, 10:39:59 AM »
ALL
I have read some of the topics on rear speakers. My question is, I have put in rear
speakers and am not sure how to wire them up to the radio. I have a 99 I/S and everthing is stock as far as I know. There is one wire ( other than the antenna) running back to the truck that ends with a Male RCA style jack. Any pics or help with this would be appreciated.
Tbone
Steve K (IA)
Cedar Rapids, Iowa
Re: Wiring question-rear speakers
June 08, 2009, 11:02:15 AM »
Are the speakers I/S specific? Did they come with a wire harness? The plug you are looking for is behind the right side cover. If your speakers came with the wire harness, you can look for the matching plug.
States I Have Ridden In
tbone
Bradford, il
June 08, 2009, 01:52:02 PM »
They did not come with a wire harness.
Momz
ABATE, AMA, & MRF rep.
June 08, 2009, 02:28:29 PM »
All I/Ss come with wiring that ends in a terminal. It should be near the right side rear fender strut. The OEM speakers also come with wiring that plugs into the terminal that I just spoke of. With OEM speakers, it's literally just "plug and play".
ALWAYS QUESTION AUTHORITY!
SCain
Rio Rancho, NM
June 08, 2009, 03:06:35 PM »
I believe Electrical Connection sells the Interstate Rear Speaker wiring harness, this will give you the correct plug. Behind the right side cover is a black 4 pin square connector, this is the rear speaker connection.
Hope this helps
Steve
Steve K (IA)
Cedar Rapids, Iowa
Re: Here You Go
June 08, 2009, 03:23:51 PM »
$14.95 for the rear speaker harness for Valkyrie Interstate.
http://www.electricalconnection.com/wire-harnesses/hrns_speaker.htm
tbone
Bradford, il
Reply #6 on:
June 09, 2009, 09:44:59 AM »
Thanks, I will order the wire harness... I appreciate the help.
Tbone
