August 13, 2025, 07:12:56 PM *
Author Topic: final drive maintenance  (Read 1504 times)
v-man1
« on: September 15, 2012, 04:32:36 PM »
Hello.When putting the final drive/wheel back together after servicing it,if the 4 bolts were not  tightened last,would it be so simple as to just loosen them and re-torque or would the whole process of disassembly be needed?Thanks
Lucky Duck
Inverness, FL
« Reply #1 on: September 15, 2012, 05:35:39 PM »
I would put the bike on a lift to get the weight reduced on the axle. Loosen the axle nut and the four bolts for the final drive. Maybe roll the wheel a time or two then torque the axle and last torque the four final drive bolts.
« Reply #2 on: September 16, 2012, 08:40:51 AM »
No diss-assembly required.
If the four bolts (studs w/nuts) were not loosened, then nothing more is needed, you're Ok.
If they were loosened up, then getting the bike weight off the wheel (lift) and loosen and re-tightening them is all that's needed.
Not that big a deal if you perform a regularly scheduled maintenance of the rear drive unit.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: September 16, 2012, 06:28:12 PM »
+1
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
robin
Get on it and RIDE!!
Hardwick NJ
« Reply #4 on: September 18, 2012, 05:10:26 AM »
I do believe you want the bike on the ground when you tighten the 4 nuts at that point the drive shaft is in the proper alignment.
« Reply #5 on: September 18, 2012, 05:41:43 AM »
Absolutely not.  You want NO stress at all on the final drive no shock mounted to it, wheel not touching anything at all....so the torque on the axle is the only force telling the final drive where to be
robin
Hardwick NJ
« Reply #6 on: September 18, 2012, 12:19:32 PM »
OK so do you put the axle through and tighten to specs and then tighten the 4 nuts?
« Reply #7 on: September 18, 2012, 03:03:36 PM »
Yep....just like that.....except (of course) you have to secure the caliper plate with the pin/bolt before torquing the axle cause it aint moving after.
« Last Edit: September 18, 2012, 03:05:15 PM by Chrisj CMA » Logged
