January 28, 2026, 09:41:46 PM *
Author Topic: Thanks, Grumpy!  (Read 2128 times)
« on: June 08, 2009, 06:54:52 PM »
I did a dyno run last year, turned 94 hp, 93 lbs torque.  I was very pleased.  Did it again yesterday, only change done to bike was a pair of Grumpy's wide mouth tips, on the same truck stacks, over cut piggies, rear baffles drilled that I ran last year.  No other tuning, not even new plugs.  Check out this dyno run, same dyno, same operator.  Hoser
Thanx again, Grumpy  Grin Grin Grin Grin Grin
MP
North Dakota
« Reply #1 on: June 08, 2009, 06:59:10 PM »
I wish it was easier to compare between dynos.  I do not trust that one says X, and the same bike on the second dyno says X + 7hp.  You really need the same dyno, and hopefully the same operator, to compare.
I just dyno'd my 97, and came up with just over 90 each hp and torque.  But, hard to compare to your numbers.
Maybe me can swap bikes for a few miles this summer, Hoser, and compare.
MP
"Ridin' with Cycho"
« Reply #2 on: June 08, 2009, 07:14:41 PM »
It was the same dyno,MP, same operator, too.  Hoser
( I'll be on the Interstate at Inzane, the dyno run was on the Tourer.)
« Last Edit: June 08, 2009, 07:16:48 PM by Hoser » Logged
MP
North Dakota
« Reply #3 on: June 08, 2009, 08:29:10 PM »
Yours were good.  I meant comparing my dyno readout to yours.  My mistake for not being clear.
MP
"Ridin' with Cycho"
mikehallbackhoe
« Reply #4 on: June 08, 2009, 08:46:02 PM »
dyno readings will change from day to day, even different time of day. changes in outdside temperature, humidity, no way to really compare two dyno readings a year apart
« Reply #5 on: June 09, 2009, 05:51:07 AM »
I agree with that, all the same, I'm very happy with the results, only other cruiser that ran better numbers was a new M109 Suzuki, at 107 horse.  What a brute!  Hoser
Grumpy
Tampa, Fl
« Reply #6 on: June 09, 2009, 08:36:50 PM »
 Cheesy Well I will not take credit for that, have to see a few more runs with and with out the tips.  But if that is the case, that the tips helped so much the better.
Like they say if you are pleased with them, Great !
