February 05, 2026, 07:37:48 PM *
Author Topic: Anti sieze on water pump bolts?  (Read 1427 times)
rmcnelly
Portsmouth, VA
« on: September 17, 2012, 05:35:32 PM »
I have a new water pump on order from HDL.  I got the bolts loose on the old one by using penetrating oil and tapping on them with a hammer with the engine warm but one of them (lower right) was really tough to break loose.
When installing the new pump should I use anti-sieze on the bolts?
« Last Edit: September 17, 2012, 06:19:02 PM by rmcnelly » Logged
--Rick
'98 Standard
« Reply #1 on: September 17, 2012, 06:16:13 PM »
I have a new water pump on order from HDL.  I got the bolts loose on the old one by using penetrating oil and tapping on them with a hammer with the engine ward but one of them (lower right) was really tough to break loose.
yes!
dreamchaser
Portland, Oregon
« Reply #2 on: September 17, 2012, 06:43:03 PM »
You should also go to your local bolt house and get new bolts, as the ones you had a hard time removing have already been involved in a bi-metalic siezure.
« Reply #3 on: September 17, 2012, 08:07:28 PM »
I put anti-sieze on then to make them easier to remove next time.
Hay Cool
rmcnelly
Portsmouth, VA
« Reply #4 on: September 18, 2012, 03:05:08 AM »
I'm hoping the top bolts come with the new pump as they are inside the outline on the parts fiche for the assembly.  I'll see if I can source the lower bolts locally.
--Rick
'98 Standard
« Reply #5 on: September 18, 2012, 09:29:19 AM »
Most anytime you have two disimilar metals antiseize be a good thing to do. That way the next time hopefully not as big a hassle for disassembly. RIDE SAFE.
rmcnelly
Portsmouth, VA
« Reply #6 on: September 18, 2012, 11:41:06 AM »
Thanks guys!
--Rick
'98 Standard
