August 13, 2025, 07:15:14 PM *
Author Topic: K & N chrome oil filter #KN 303C fit 2003 standard?  (Read 1127 times)
boss hoss bill
« on: September 18, 2012, 08:54:04 AM »
Came across this puppy on EBay, is advertised for a 1999 Interstate.
K&N Oil Filter 1999 HONDA GL1500 VALKYRIE INTERSTATE 1520 KN-303C
K&N powersports oil filters are "TUV" product endorsed and "TUV" factory production monitored. Our filters contain a modern synthetic filter media, designed for ultimate flow with less pressure drop, yet engineered for outstanding filtration. K&N powersports "spin-on" oil filters feature a heavy-duty metal can. Most of these have a 17mm nut affixed onto the end that allows for easy installation and removal. The 17mm nut is crossed-drilled so racers can safety wire the filter to their bike.
Part KN-303C Product Specifications
Product Style: Oil Filters
Height: 3.346 in (85 mm)
Outside Diameter: 2.673 in (68 mm)
Thread Inside Diameter: M20 x 1.5
PSI Relief Valve: Yes
Anti Drain Back Valve: Yes
Style: Canister
Removal Nut: Yes
Gasket Material: Nitrile Rubber
Filter Material: High Flow Premium Media
Bypass Valve: Yes
Finish: ChromeWeight: 0.58 lb (0.26 kg)
Product Box Length: 2.75 in (70 mm)
Manufacturer:K&N
Manufacturer Part Number: KN-303C-1026
Fits: 1999 HONDA GL1500 VALKYRIE INTERSTATE 1520
Will this work on my 2003 standard?
TIA
Bill
« Reply #1 on: September 18, 2012, 09:20:04 AM »
I would like to say yes but to be sure go to the H D L website and cross reference the 2 filter #s in question. Look up a 99 I/S and your 03 standard. If your #s match yer good to go. RIDE SAFE.
« Reply #2 on: September 18, 2012, 09:59:09 AM »
Yes it will.  I use them all the time.  They are chrome and have the safety wire holes in the 17mm nut on the front.  Not that I have ever used those holes, but they are there.
Hay  Cool
« Reply #3 on: September 18, 2012, 12:46:34 PM »
Yes!  Except for a couple tweaks in the carbs and timing it's the same engine in all the Valks.
boss hoss bill
« Reply #4 on: September 18, 2012, 02:28:05 PM »
Thanks Guys
It's on the way!
John Schmidt it's great to see you active on the board again.  :cooldude:Best wishes for a fast and complete recovery!
« Reply #5 on: September 18, 2012, 05:01:26 PM »
Their claim of a "high flow" filter media is just like their air filters. Bigger pores mean worse filtering. Get the Purolator Pure One filter (PL14610) and don't worry about grit running through your engine.
