August 13, 2025, 07:23:06 PM *
Author Topic: Axles interchangeable?  (Read 1071 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: September 19, 2012, 01:06:20 AM »
Front axles for early and later Valks  have different part numbers.  Will the later ones (2000) fit my '97 Standard?
Disco
Republic of Texas
« Reply #1 on: September 19, 2012, 03:18:46 AM »
Yes.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
« Reply #2 on: September 19, 2012, 07:17:01 AM »
When did the part number change ??  The 97s used a smaller bearing,, but,, I don't remember what about the bearing was smaller..
fiddle mike
Corpus Christi, TX
« Reply #3 on: September 19, 2012, 08:29:46 AM »
The number changes 1999.
« Reply #4 on: September 19, 2012, 03:25:08 PM »
Well, if 97 to 99 axles are the same then maybe they are all the same,, I'm not aware of any changes in the later years.. But,, I don't know for sure..
Disco
Republic of Texas
« Reply #5 on: September 19, 2012, 03:31:51 PM »
The '97 front 6004 bearing is 42mm in outer diameter, 12mm thick, and has a 20mm hole.
The '98-'03 front 6204 bearing is 47mm in outer diameter, 14mm thick, and has the same 20mm hole.
78 CB550K
fiddle mike
Corpus Christi, TX
« Reply #6 on: September 19, 2012, 04:58:30 PM »
Thanks.  cooldude
