August 13, 2025, 07:23:24 PM *
Author Topic: Slap - Clunk...  (Read 1538 times)
Big Rig
Woolwich NJ
« on: September 19, 2012, 06:04:30 PM »
So riding home this evening, I hit the brakes and heard a slap clunk sound from the front end. It happned a couple times, not in a row. Any ideas?
sugerbear
wentzville mo
« Reply #1 on: September 19, 2012, 06:47:33 PM »
calipers tight? rotors?
JaysGone
Delray Beach Florida
« Reply #2 on: September 19, 2012, 08:55:41 PM »
Spring in the caliper holding the pads needs to be tightened up.
Just give it a bend.
I just had the same issue in my right front caliper 2 weeks ago.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
Danny
Tucson, Az
« Reply #3 on: September 19, 2012, 09:14:09 PM »
Sometimes my brakes make a clunk noise when stopping....did you feel any vibration in the handlebars or possibly from the seat....try to give you a idea if the issue is in the front or the back.
« Reply #4 on: September 20, 2012, 08:13:48 AM »
Yeah,
Investigate further!
Red Diamond
Beaumont, Texas
« Reply #5 on: September 21, 2012, 06:10:05 PM »
See those big round rivets that separate the disk brake rotor from the inner rotor, that's what is making the clank or clunk you are hearing. Roll your bike backwards and hit the brakes, you should hear a clank, then roll it forward, you should hear the same clank. The rivets are starting to roll a little. These rivets keep the heat from getting to your front wheel bearing.
« Reply #6 on: September 22, 2012, 06:25:09 AM »
That is certainly a possibility.
You can grab the rotor and move it actually with your hand. Mine do!
They make no noise however.
