August 13, 2025, 07:23:11 PM
Key broken off in gas cap
Topic: Key broken off in gas cap (Read 1164 times)
Longhorn
September 19, 2012, 11:32:02 PM »
A buddy of mine broke his key off in the gas cap lock. I've heard tweezers, dental picks, epoxy a tooth pick and pull it out?? and take hinge loose and take cap to a lock smith or some such. Has anyone solved this problem before? He's not quit sure what to do and wants to fix it on the cheap. Help
hueco
WACO,TEXAS
Re: Key broken off in gas cap
September 20, 2012, 12:25:56 AM »
OK? Is it you or your buddy? Don't matter.
I or my buddy would take it to a locksmith. If I or my buddy could not fix it. Your secret is safe with us.
September 20, 2012, 06:24:22 AM »
Vee haff wayz of making you tell da truff.
RIDE SAFE.
September 20, 2012, 08:03:21 AM »
A lot depends upon how much of the remaining part inside the tumbler is revealed allowing it to be grabbed.
You must remember that the remaining part will not be allowed to be pulled out with the lock in "open" position.
Push the spring loaded ring inside the cap to allow the lock to turn back to the "locked" position.
Longhorn
September 21, 2012, 10:25:57 PM »
Thanks all. I'm passing it on to the neighbor. He's a cop so don't f with him. He is monitoring u. He has ways to make u tell the truth.
SDS
OKC
September 22, 2012, 04:18:58 PM »
Sometimes you can take a fine tooth jigsaw blade and sort of "grab" the broken key with the last tooth on the blade and then pull it out. I have had to grind the jigsaw blade down so that (front to back/cutting edge to spine) is narrower in order to get the tip deep enough to grab the broken key.
SDS
www.sdsknifeworks.com
=> InZane XXV
