February 05, 2026, 10:55:08 PM *
Author Topic: May I ask a dump question?  (Read 1550 times)
Dave S. UK
« on: September 28, 2012, 09:54:39 AM »
Hi... I need to adjust my Interstate headlight so shine further down the road I suspect that I need to tighten the large upper grey adjuster's can anyone please confirm?....thanks Dave S. UK cooldude
Fritz The Cat
« Reply #1 on: September 28, 2012, 10:01:38 AM »
Am I correct in assuming that what you refer to as "dump" is what we call "dumb" on this side of the pond?  crazy2
Dave S. UK
« Reply #2 on: September 28, 2012, 10:14:54 AM »
Ha ha next time I'll double check before I post  Dave S.  2funny
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #3 on: September 28, 2012, 11:00:14 AM »
Yes - turn them clockwise (hey - at least that description carries true across the pond haha) to raise the beam.  Recommend small adjustments, and you can reach them with the whole fairing intact - doesn't take much force to turn them.
« Reply #4 on: September 28, 2012, 11:16:58 AM »
My high beams on my I/S shine great and far ahead and well lit all over and don't want to adjust.  But, the low beams at night sure suck and when cars come at me, I have to slow down to 55 mph or so to see adequately ahead in the road for fear of not being able to slow down if something on road up ahead.  Too bad there is no separate adjustment for low and high beams.
Dave S. UK
« Reply #5 on: September 28, 2012, 11:30:55 AM »
Thanks again...I'm off out to the garage and sort it out once and for all...might get a few miles in if it  stop's raining Dave.  cooldude
ShiftHappens
South Suburbs Chicago, IL
« Reply #6 on: September 28, 2012, 11:36:57 AM »
My IS is fine on low and high. Are you using the honda bulb? I remember reading of an adapter ring for H4 bulbs so they will be correctly positioned. They are about 12 bucks for the pair. I had thought of getting on hand for my next bulb burnout and replacement.
1999 Interstate
« Reply #7 on: September 28, 2012, 02:10:30 PM »
I went to the Napa bulbs suggested on this board-cut off the 2 tabs and my low and high beams are just fine-without the adapter rings. F T C-i'm glad YOU aked the question. RIDE SAFE.
texaninsouthfl
Serving those who served us...
East Lake County, Florida
« Reply #8 on: September 28, 2012, 09:56:20 PM »
Well I thought this thread was going to be more entertaining that it turned out to be...  2funny
