November 25, 2025, 10:30:14 AM *
Author Topic: Clutch Bleeder Location  (Read 1244 times)
DavidT
Clearlake
« on: September 29, 2012, 09:50:40 AM »
Okay, I give up.  Where did Honda hide the bleeder valve for the clutch?  I tried following the hose down from the lever, but it just disappears under the tank and I can't find where it comes to the slave...and I don't know where the slave is.  Cheesy Posting this question is my last resort, I've been through countless posts, forums and diagram sites with no luck.
David
« Reply #1 on: September 29, 2012, 10:13:35 AM »
Where you put the key in to unlock the seat-just to the right of that as you sit on the M/C-see a bright shiny thingy sticking out-thats the clutch bleeder. It's basically pointing forward. Hope this helps. RIDE SAFE.
DavidT
Clearlake
« Reply #2 on: September 29, 2012, 10:28:08 AM »
Perfect!  Found it, thanks!
Red Diamond
Beaumont, Texas
« Reply #3 on: September 29, 2012, 10:29:41 AM »
Where you put the key in to unlock the seat-just to the right of that see a bright shiny thingy sticking out-thats the clutch bleeder. It's basically pointing forward. Hope this helps. RIDE SAFE.
« Reply #4 on: September 29, 2012, 03:58:32 PM »
Glad my description got you where you needed to be.  coolsmiley If you haven't yet-a Clymer manual or a Honda service manual helps a LOT. Look up Dags downloadable manual. And this board i've found out over a couple of years is more than willing to help out.  cooldude RIDE SAFE.
