Blues
'03 Standard Black Beauty
NW Arkansas
« on: October 04, 2012, 02:14:01 PM » |
I've been putting off doing an inspection on my drive shaft splines and figuring I should look at the rear wheel gears as well. I probably also need to look at my u-joint.
But before I can do that, I need to get my supplies in order. I'm thinking I need a set of O rings, maybe a wheel thrust washer, gear oil, ???
Does anyone have knowledge of what the part numbers are and where's the best place to order them from? I know this has been discussed a zillion times, but I guess it is something that we each have to do on our own. I very much appreciate any and all information I can get. If you have suggestions on anything else I need, please let me know.
Thank you so much for any advice you can offer!
Blues
NW Arkansas
« Reply #1 on: October 04, 2012, 02:18:27 PM » |
I also just remembered that I need new shock bushings...
« Reply #2 on: October 04, 2012, 02:35:45 PM » |
order from HDL they ship right to you http://www.hdlparts.com/
« Last Edit: October 04, 2012, 03:26:25 PM by Chrisj CMA »
rider
« Reply #3 on: October 04, 2012, 05:46:25 PM » |
try doing a search of rear end teardown theres a post in that thread with oem part numbers your after,carolinabikeandtrike worked great for the 3 orings.goodluck
Blues
NW Arkansas
« Reply #4 on: October 05, 2012, 07:04:47 AM » |
Thanks for the info!!! I'll start there.
whitestroke
« Reply #5 on: October 05, 2012, 01:45:52 PM » |
« Last Edit: October 05, 2012, 01:47:49 PM by whitestroke »
Minibike Honda S90 Yamaha YL100 Bultaco 250 Matador Bultaco 250 Pursang Yamaha 250 YZ Triumph 650 Bonni Honda ATC 200
2 Kids 25 year break. Suzuki GS 500 2003 VTX 1300S, 1998 Valk standard 2008 Goldwing
« Reply #6 on: October 05, 2012, 05:44:38 PM » |
« Reply #7 on: October 06, 2012, 01:04:49 PM » |
Where you're located in Arkansas, I'd use Service Honda in Indiana. I've had overall faster service from them than HDL, same prices within pennies.
Blues
NW Arkansas
« Reply #9 on: October 08, 2012, 08:21:05 AM » |
All good information. Thanks to everyone for the advice!!!
